asus x401a rev 2.0 locked input voltage 19v
  • manh trung
    • Aug 2020
    • 53
    • vietnam
    This x401a mainboard is losing voltage from the adapter 19v when going through pq8801 and pq8802.
    voltage levels i measured at ic bq25a
    pin 20. 18.7v
    pin 5. 2.99v
    pin 6. 2.5v
    pin 4. 0v
    i have replaced many charge controller ic but to no avail. no short circuit detected and 2 open-source mosfets pq8801 and pq8802 also replaced
    frank martin
  • mon2
    • 14320
    Re: asus x401a rev 2.0 locked input voltage 19v
    Measure the voltage to ground of REGN pin on the charger IC BQ25A.
    Also, ACDRV.
    What are the measurements?
    • manh trung
      • Aug 2020
      • 53
      • vietnam
      pin 16. 6v
      pin 4. 0v
      i replaced 4.02k resistor at ACDRV pin, impedance is good but voltage is always 0v
      did not detect anything out of the ordinary in the pins. thanks you
      frank martin
      • mon2
        • 14320
        Remove the 4k resistor and measure the voltage again at the ACDRV pin.
        • manh trung
          • Aug 2020
          • 53
          • vietnam
          no voltage
          frank martin
          • Sephir0th
            • Oct 2020
            • 1283
            Pictures of your soldering job please.
            FairRepair on YouTube
            • manh trung
              • Aug 2020
              • 53
              • vietnam
              sorry. Due to daily work, I temporarily put this motherboard on hold. but i want some advice
              frank martin
              • mon2
                • 14320
                When you have quality time, do flux and apply ample heat and low air pressure to make this charger IC swim in the liquid solder. Follow the Louis Rossmann advice, make it 'dance' with a gentle corner nudge with tweezers. The chip will push away and bounce back, naturally onto the PCB pads. Be patient and DO NOT force the push otherwise the PCB pads will be ripped off the PCB.
                Once you do this, any short will be removed. The pads will align 'like soldiers'.
                Then check ACDRV pin again (without the series resistor). Since you have power to the device AND REGN is ~6 volts, the ACDRV pin should be ~25 volts - unless this IC is defective. Most likely, not soldered properly as noted above by @Sephir0th.
                • manh trung
                  • Aug 2020
                  • 53
                  • vietnam
                  Thanks for advices. I will try to report back the results
                  frank martin
                  • manh trung
                    • Aug 2020
                    • 53
                    • vietnam
                    after soldering the pins of the ACDRV ic there was 24v but when I soldered the 4.02k resistor back to the circuit the ACDRV was 0v again. apparently the fault belongs to the 2 mosfets open source 19v from the adapter. it's N channel mosfet with max current 48A and 30v i replaced these 2 mosfet with equivalent but still no result
                    frank martin
                    • mon2
                      • 14320
                      Very good.
                      Remove the 2nd dcin mosfet and power up again.
                      What is the ACDRV pin voltage to ground?
                      If ~25v, then remove all power. Meter in resistance mode.
                      Measure the resistance to ground of the 2nd mosfet pins.
                      Source (1-2-3) to ground.
                      Gate (4) to ground.
                      Drain (5-6-7-8) to ground.
                      Post each measurement.
                      • Fernon@Repair
                        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                        by Fernon@Repair
                        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                        VCCIO voltage ok
                        VCCSA Voltage OK
                        VCCPLL Voltage OK
                        Ram Voltage ok
                        RamVTT OK
                        VPP 2.5 OK
                        But No Core Voltage
                        and i want to this vrm ic datasheet or pinout (ISL69269)
                        anyone have this ic pinout voltages?...
                        06-25-2025, 07:19 AM
                      • electron_jj
                        Panasonic TH-L42D25A checking the PSU output voltage
                        by electron_jj
                        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                        08-29-2021, 08:13 AM
                        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                        Now...
                        06-09-2024, 10:57 AM
                        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                        Based on Intersil's Robust Ripple Regulator...
                        11-05-2024, 03:24 PM
                      • ruletero
                        Acer a515-43 low battery charge voltage
                        by ruletero
                        Hi
                        Acer A515-43
                        LA-H801P
                        Fail: Does not charge battery, has low voltaje on connector.
                        Laptop didn't want to turn on, only charge led blinked.
                        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                        10-24-2022, 02:31 PM
