LA-F115P +19VB = 13.6v instead of 19v
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    I getting 13.6v instead of 19 on this board
    I have measured D1 of PQB02 (AON6994) and getting same 13.6
    I dont know how to test those Dual Asymmetric MOSFET
    Can you please help me understand which IC is failing ?
    attached link to schematic and boardview
    https://www.badcaps.net/forum/showth...light=la-f115p
  • mon2
    • Dec 2019
    • 14370
    Re: LA-F115P +19VB = 13.6v instead of 19v
    Do you have 19V at the adapter level ?
    Is the battery connected ?
    What is the voltage of the battery at the battery connector ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      13.6V is very likely correct as NVDC is involed here.
      • koby058
        • Jan 2017
        • 387
        • israel
        HI,
        yes 19v present in the adapter level
        battery not connected.
        I dont have the batt near me at the moment
        • koby058
          • Jan 2017
          • 387
          • israel
          13.6V is very likely correct as NVDC is involved here.
          the laptop fan turns on for a second and then stopes. there is no post.
          when the power button pressed, i see about 0.8v in PLI01/02 and around 0.9 on PLV01/02.
          I get hit from CPU.
          Can you guys please suggest another test direction ?
          • rediii
            h???, spurrrn
            • Mar 2018
            • 490
            • somewhere in europe
            I get hit from CPU.
            did you try another original charger?
            • koby058
              • Jan 2017
              • 387
              • israel
              I will have one in the evening, when i will get it i will test
              • koby058
                • Jan 2017
                • 387
                • israel
                Just to understand you, even though it says 19v in schematic and i have 13.6 on this coil (PLV11) it is still reasonable ?
                • mon2
                  • Dec 2019
                  • 14370
                  Correct.
                  https://en-support.renesas.com/knowledgeBase/6680047
                  • koby058
                    • Jan 2017
                    • 387
                    • israel
                    tried with another good charger still same.
                    voltage on bat 11.3v
                    I can also see that the capslock is always on
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 490
                      if no suspicious measuring occurs, try a known good bios
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        You beleive it or not but 13.6V as main rail is correct. You are getting vga core/cpu core and thats a good sign.
                        On page3/4, you have all the rail listed. Find out what is missing.
                        What is the consumption on your dc supply
                        01.When off
                        02.When turned on with ram stick
                        03.When turned on without ram stick.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes, flash known good clean me bios as@rediii has suggested.
                          • koby058
                            • Jan 2017
                            • 387
                            • israel
                            Hi
                            I have tried bios and got the same results.
                            https://www.badcaps.net/forum/showthread.php?t=112763
                            Any other suggestion ?
                            • Sephir0th
                              • Oct 2020
                              • 1283
                              Share exactly what voltages you get in the short time where the board is on, each coil. Also resistance to GND of all coils.
                              Also pay attention to what testing methods the other member have shared here. Mcplslg123 has already told how to proceed.
                              FairRepair on YouTube
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                The problem with most of the members here is that they just want a readymade solution to their problem. They dont want to struggle it out. When your efforts are half baked, results will be not on expected lines.
                                Honestly, sometimes i dont feel like suggesting anything.
                                • koby058
                                  • Jan 2017
                                  • 387
                                  • israel
                                  I am sorry you feel that way, actually i am willing to put the effort but as a newbe on this area it is sometimes can be a bit overwhelming and some times you feel like you even don't know where to start. so i would like to thank you for your suggestions and help and also i understand you side.
                                  Sepfiroth I will try what you and mcplsg123 suggested and post back
                                  • koby058
                                    • Jan 2017
                                    • 387
                                    • israel
                                    Let me share what happened today.
                                    I started my work place dell laptop and saw that the caps lock is turning on for a few sec so i thought may be it is a screen issue, so i have connected it to external monitor and it booted. so you where right from the beginning.
                                    Now it is complaining it does not recognizing the adapter power i will test to see if adapter signal is there and will post here
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Nice to know that the unit is working. Try with another dell original known good adapter.
                                      If adapter is still not recognised, you have alikely fault in PS_ID circuit which is very simple to solve. Check whether PS_ID is present on pin36 of SIO and 33 Ohms resistor is intact or not.
                                      • koby058
                                        • Jan 2017
                                        • 387
                                        • israel
                                        Will take me time, i will check and notify here, thanks a lot
                                        • juergenb
                                          Dell 5570 - LA-F115P, Dead
                                          by juergenb
                                          i am new here and try toy to repair a dead Dell 5570, with i5 and AMD GPU.
                                          Before purchasing any Hotair or Microscope equipment i try to repair with my equipment and a handheld lens for stamps/coins...
                                          The Board has no sign of life, if 19V is connected i hear a hissing sound.
                                          I checked Power Rail at DC in an 19V seems fine so far.
                                          I have schematics, Scope, Multimeter, DC Bench Power Supply with Current limiting (HP/Agilent).
                                          Schematics is "Dell Inspiron 15 5570 LA-F115P CAL50 DAL10 REV 1.0 (A00)"
                                          I think that the...
                                          03-21-2021, 04:28 AM
                                        • dclass-pro
                                          Dell not charging battery LAF115P Battery and PSU Original
                                          by dclass-pro
                                          Hi guys I have a DELL that does not charge.
                                          I bought new original battery and charger and when it turns on the percentage of charge drops.
                                          here is the link to the diagram:https://www.badcaps.net/forum/troubl...oogle_vignette
                                          I checked that on the +SDC_IN pin I have 19.8V
                                          on ISL9538HRTZ
                                          Pin 17 = 19V
                                          Pin 18 = 5V
                                          Pin 19 = 3.6V
                                          Pin 21 = 3.1V
                                          Pin 22 = 3.1V
                                          Pin 24 = 3V
                                          04-29-2025, 09:58 AM
                                        • javieromex
                                          Dell G15 5511 LA-K452P won't turn on
                                          by javieromex
                                          Hello, any help will be apprecited!
                                          • Model: Dell G15 5511
                                          • MB: LA-K452P
                                          • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                          • Customer reported it was turned off and left plugged in during the night and thats it...
                                          • No signs of liquid damage or burned components.
                                          Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                          I have checked so far:
                                          04-17-2025, 12:44 PM
                                        • CPUFiddler
                                          Acer Nitro 5 AN515-45 not charging
                                          by CPUFiddler
                                          Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                                          This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                                          I've downloaded...
                                          03-19-2025, 07:44 AM
                                        • andrhouseolly
                                          Acer Aspire 5 a515-52g, EH5AW LA-G521P Rev.1a does not start.
                                          by andrhouseolly
                                          Hi goodday to all.
                                          I really ask for help.
                                          There are two motherboards (absolutely identical) Acer Aspire 5 a515-52g, EH5AW LA-G521P.
                                          Both boards have exactly the same fault symptoms. It turns on, the power indicator lights up for 5 seconds, turns off (the fan does not spin).
                                          Both boards are flashed with Bios Main and Bios EC from the “Bios Acer A515 LA-G521P FULL TEST” topic. XM25QH128AHIG replaced by W25Q128JVSIQ (also NOR-FLASH, XM was not detected by the programmer). On one of the boards, KB9022 was changed, followed by firmware. The fault persists on both boards....
                                          03-29-2024, 02:41 PM
