LA-F115P +19VB = 13.6v instead of 19v
+ More Options
Posts
  • koby058
    • Jan 2017
    • 387
    • israel
    Re: LA-F115P +19VB = 13.6v instead of 19v
    Nice to know that the unit is working. Try with another dell original known good adapter.
    If adapter is still not recognised, you have alikely fault in PS_ID circuit which is very simple to solve. Check whether PS_ID is present on pin36 of SIO and 33 Ohms resistor is intact or not.
    I have checked resistance is 33ohm and i have 3.3v on pin36 but still it complains it cannot recognize adapter
    Since it is not a bios issue i have reflashed the original BIN that i have backed up before changing bios still not recognizing the adapter
    what else it could be ?
    • mon2
      • 14627
      Measure the voltage to ground on both sides of PL3 with the power adapter connected.
      Then remove PL3 for a quick test. Measure the voltage at PL3 again and post all readings.
      • koby058
        • Jan 2017
        • 387
        • israel
        voltage is 3.3v when connected
        is removing it and measure == measure on pin 3 on the charging port when it is disconnected from board?
        if yes then voltage on pin 3 of charging port is 0v
        I am asking since it will take me time to remove
        • mon2
          • 14627
          Hmm. You should have some voltage on pin # 3 of the charging port side since this is the voltage that the local EC controller will sample (Analog to Digital conversion) to determine the power rating of the adapter.
          Can you check if the voltage is present if you float the power connector in the air ? This same power adapter functions to power other laptops OK ?
          If the voltage is present if you DO NOT connect to this board, then check the connections of the DC in power connector. Also, with NO power, check the resistance to ground of this same pin #3 on the charging port. Perhaps some short to ground that is halting this PS_ID from working.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Besideds@mon2's suggestion, check whether ACOK is pulled low.
            • koby058
              • Jan 2017
              • 387
              • israel
              #26
              SOLVED: LA-F115P +19VB = 13.6v instead of 19v
              Hi, thank you all for your help.
              It was a great learning experience, I have brought (laptop tests was at home) a new charger and new charging port (eventually was not used), and the laptop works ok now.
              I am really appreciate the time and effort invested here by you
              • mferna14
                • Jun 2018
                • 1042
                I have identical problem in this model. No AC power adapter detected. PSID is fine, get 3.3 volts, ACOK is fine. But I still cannot understand the logic of 13.5V on the main 19v rail. Why do the MFG. want voltage to drop with this buck converter. Can someone pls. explain me this logic???
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Read about NVDC technology in charging circuit and it'll be clear to you why 13.5V as main rail is correct.
                  • mferna14
                    • Jun 2018
                    • 1042
                    Thanks for the info.... Now inform me why is the laptop not working on AC power. But at time when I remove the motherboard & turn it on Stand alone, it works perfectly on AC power, the moment I attach the battery terminal, NO AC POWER DETECTED. Can you please help me in this. Thanks
                    • mon2
                      • 14627
                      Is the adapter being detected ok if the battery is removed?
                      If not...
                      Check the continuity of the PS_ID line to the actual connector contact on the DC power jack.
                      If it is ok, measure the voltage to ground of the protection mosfet (source / drain / gate).
                      Post each measurement.
                      Sounds like you have a leaky 2nd DCin mosfet if the battery and AC adapter cannot coexist.
                      Remove all power -> meter in resistance mode -> check the resistance across the 2nd DCin mosfet.
                      source (1-2-3) & drain (5-6-7-8)
                      source (1-2-3) & gate (4)
                      gate (4) & drain (5-6-7-8)
                      • mferna14
                        • Jun 2018
                        • 1042
                        Thanks @mon2 for the quick response. I will do this tomorrow, as I close right now & will come fresh with all these troubleshooting methods. Will surely inform you tomorrow.
                        • mferna14
                          • Jun 2018
                          • 1042
                          mon2., PSID continuity is perfect. Right now I want to inform you about the intial two MOSFET (both PNP) PQ3 & PQ4. 19v enters the source of PQ3. Now accourding to the schematics there is a voltage dividers on the Gate (1Mx1M). Out here I am getting 18.1v, which is not right, according to the divider formula, the voltage should be around 9.79 volts. So something is wrong in the initial stages. Now except for 19v ponits I am not getting any voltages on the board because PQ3 is not by passing the 19v to PQ4 & the board. So now pls. guide me. I have to check PQ3 gate & correct these voltages. I shorted/soldered a wire to see any difference, but nothing, still does not turn on with AC power. Both MOSFET are ok. Not getting +3.3V_ADP_DCIN & this is generated through PU1 RT9069-33GB_SOT23-5, Input 19v pin 1 is fine, EN pin 4 is ok, output pin 5 varies, & I observe it now, it is getting hot, poured alcohol on it, just sparked ^_^. Is there any replacement for this chip RT9069-33GB_SOT23-5 ??? Thanks
                          • mon2
                            • 14627
                            Remove all power and measure the resistance to ground at the output of this LDO regulator that is getting hot.
                            Replacements are available from Digikey:
                            https://www.digikey.ca/en/products/d...9-33GB/5270908
                            • mferna14
                              • Jun 2018
                              • 1042
                              Thanks., will do this what you told me.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #35
                                Working on a dell G3 gaming laptop-works on battery but dont work on adapter. After taking the board out, RT9069-33GB is blown. Removed the component, checked resistance on input/output/enable and soldered a new RT9069-33Gb. Working perfectly on adapter. So may be you too will have success.
                                • mferna14
                                  • Jun 2018
                                  • 1042
                                  Thanks mcplslg123 for this update... I just have to find one RT9069-33GB on a donor, before I start to order them. mon2 & mcplslg123 are great help!!!
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    #37
                                    RT9069-33GB is very sparingly used-I've seen only 3-4 models with this chip so far and that too in Dell only. So may not be available in scrap boards. Better order online and order a couple of pcs more for future usage. The chip is available at less then 1$ per piece
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #38
                                      For testing purpose, you can use a buck coverter card set to 3.3V on output pin of RT9069 but ultimately the chip needs to be replaced.
                                      • mferna14
                                        • Jun 2018
                                        • 1042
                                        "mcplslg123" received this regulator RT9069-33GB today. Replaced it & all worked like charm. No problems at all. Now I got a lot in stock. Thank you very much for all the help.
                                        • mcplslg123
                                          • Jun 2015
                                          • 7262
                                          • india
                                          #40
                                          Glad to hear you fixed it.
                                          • juergenb
                                            Dell 5570 - LA-F115P, Dead
                                            by juergenb
                                            i am new here and try toy to repair a dead Dell 5570, with i5 and AMD GPU.
                                            Before purchasing any Hotair or Microscope equipment i try to repair with my equipment and a handheld lens for stamps/coins...
                                            The Board has no sign of life, if 19V is connected i hear a hissing sound.
                                            I checked Power Rail at DC in an 19V seems fine so far.
                                            I have schematics, Scope, Multimeter, DC Bench Power Supply with Current limiting (HP/Agilent).
                                            Schematics is "Dell Inspiron 15 5570 LA-F115P CAL50 DAL10 REV 1.0 (A00)"
                                            I think that the...
                                            03-21-2021, 04:28 AM
                                          • dclass-pro
                                            Dell not charging battery LAF115P Battery and PSU Original
                                            by dclass-pro
                                            Hi guys I have a DELL that does not charge.
                                            I bought new original battery and charger and when it turns on the percentage of charge drops.
                                            here is the link to the diagram:https://www.badcaps.net/forum/troubl...oogle_vignette
                                            I checked that on the +SDC_IN pin I have 19.8V
                                            on ISL9538HRTZ
                                            Pin 17 = 19V
                                            Pin 18 = 5V
                                            Pin 19 = 3.6V
                                            Pin 21 = 3.1V
                                            Pin 22 = 3.1V
                                            Pin 24 = 3V
                                            04-29-2025, 09:58 AM
                                          • javieromex
                                            Dell G15 5511 LA-K452P won't turn on
                                            by javieromex
                                            Hello, any help will be apprecited!
                                            • Model: Dell G15 5511
                                            • MB: LA-K452P
                                            • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                            • Customer reported it was turned off and left plugged in during the night and thats it...
                                            • No signs of liquid damage or burned components.
                                            Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                            I have checked so far:
                                            04-17-2025, 12:44 PM
                                          • CPUFiddler
                                            Acer Nitro 5 AN515-45 not charging
                                            by CPUFiddler
                                            Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                                            This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                                            I've downloaded...
                                            03-19-2025, 07:44 AM
                                          • andrhouseolly
                                            Acer Aspire 5 a515-52g, EH5AW LA-G521P Rev.1a does not start.
                                            by andrhouseolly
                                            Hi goodday to all.
                                            I really ask for help.
                                            There are two motherboards (absolutely identical) Acer Aspire 5 a515-52g, EH5AW LA-G521P.
                                            Both boards have exactly the same fault symptoms. It turns on, the power indicator lights up for 5 seconds, turns off (the fan does not spin).
                                            Both boards are flashed with Bios Main and Bios EC from the β€œBios Acer A515 LA-G521P FULL TEST” topic. XM25QH128AHIG replaced by W25Q128JVSIQ (also NOR-FLASH, XM was not detected by the programmer). On one of the boards, KB9022 was changed, followed by firmware. The fault persists on both boards....
                                            03-29-2024, 02:41 PM
