Default hp bl50 la-d704p dead only charge
  • darckreign1984
    • 260
    • Romania
    -laptop its charging.
    dont start.
    3VALWP +3VALW - PJP2 jumper on the motherboard its shorted to ground
    all pins from lan conectors ar shorted.
    when i inject voltage to pjp2 - GPU from processor its heating. 1.4v injected, and consume about 5A
    hp bl50 la-d704p
    rev 4.0
    la-d70
    date code: 7J1690
    SPS:858581-601
    MO:42704119
    451A1032L37 40K2
    5BG404BDL52 U37 SKL
  • darckreign1984
    • 260
    • Romania
    Re: Default hp bl50 la-d704p dead only charge
    grey coil that have voltage its only the one near battery connector - for charge
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Do you mean smaller die on the SOC??
      • darckreign1984
        • 260
        • Romania
        yes i mean the small dye integrated in processor. laptop dont have a dedicated one
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Sorry, mb may not be repairable by you as SOC needs to be replaced. You need bga machine,stencil,balls etc besides the necesaary expertise. Moreover, new reliable SOC is hard to find.
          So, end of story.
          • darckreign1984
            • 260
            • Romania
            I buy this laptop for parts.
            i dont think its worth investment.
            have a nice day
            • ipatch
              troubleshooting microsoft surface pro 4 no power no led charge light
              by ipatch
              hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
              10-05-2023, 11:59 AM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
            • Klevjetack
              Charge a L19D3PDA battery externally from the laptop
              by Klevjetack
              Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
              03-05-2024, 07:26 AM
              Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
              The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
              The bq24745 features dynamic power management...
              10-23-2024, 02:50 AM
            • hpman
              ASUS T100HA not charge
              by hpman
              I got a T100HA tablet without a charger. I want to identify the power adapter for this unit and found that it requires a 9V input.
              When the tablet is running, the 9V input will not charge it. Only when the tablet is turned off, the 9V input will charge it.
              I could use a 5V charger to charge this unit at any time. However, if I use 5V during usage, the input power is insufficient for the power consumption.
              After 1-2 hours, I must turn off the tablet to charge it.
              I love this tablet as it meets my needs. Does anyone know how to fix this issue and allow me to...
              07-31-2024, 10:01 PM
