ASUS T100HA not charge
  • hpman
    • Jul 2024
    • HONG KONG
    I got a T100HA tablet without a charger. I want to identify the power adapter for this unit and found that it requires a 9V input.
    When the tablet is running, the 9V input will not charge it. Only when the tablet is turned off, the 9V input will charge it.
    I could use a 5V charger to charge this unit at any time. However, if I use 5V during usage, the input power is insufficient for the power consumption.
    After 1-2 hours, I must turn off the tablet to charge it.
    I love this tablet as it meets my needs. Does anyone know how to fix this issue and allow me to keep the tablet on? Thank you.
  • Elektronror
    Asus GL702VS No charge, unstable GPU power
    by Elektronror
    First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
    Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
    02-05-2021, 10:39 AM
  • hayezy09
    Asus rog ally, no charge issue relating to the ite super io chip
    by hayezy09
    Hows it going just wandering if anyone has had any luck repairing rog ally’s no charge issue relating to the ite super io chip, swapped out two of these chips i bought off two different sellers on aliexpress and still no luck, both devices power on from battery but will not charge, cant find any kind of definitive answer online on wether they need to be programmed or not, either they do need to be programmed or the chips i have are no good was just wandering about anyone else’s experiences with repairing this paticular problem, cheers.
    10-09-2025, 12:12 PM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
    HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
    This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-06-2024, 07:10 AM
