8030/8039mosfet
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    8030/8039mosfet
    i want partnumber of mosfet, DFN package
    8030
    8039
    used in Medion E15403 laptop
  • mon2
    • Dec 2019
    • 14334
    Re: 8030/8039mosfet
    See attached. Nothing special.
    Each is a N-channel mosfet in a 5*6mm package. Find a high current version (low on resistance) and the same part can be used for both replacements.
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      Re: 8030/8039mosfet
      Not intierly, one is P channel
      • mon2
        • Dec 2019
        • 14334
        Re: 8030/8039mosfet
        Not entirely, one is P channel
        Which one? Can you link or share the datasheet of the mosfet in question / schematic for this logic board?
        • Dinneke
          • Apr 2014
          • 154
          • Netherlands
          Re: 8030/8039mosfet
          Sorry no further data available
          • Dinneke
            • Apr 2014
            • 154
            • Netherlands
            Re: 8030/8039mosfet
            board ip3_kn16_mb_v21_20190706a
            • Dinneke
              • Apr 2014
              • 154
              • Netherlands
              Re: 8030/8039mosfet
              8030 = N channel
              8039 = P channel
              • mon2
                • Dec 2019
                • 14334
                Re: 8030/8039mosfet
                The above linked datasheet for 8039 states it is an N-channel.
                Do you have any topside markings you can post? From the internet searches, the 8039 part is N-channel.
                • Dinneke
                  • Apr 2014
                  • 154
                  • Netherlands
                  Re: 8030/8039mosfet
                  abviously NOT Toshiba part
                  i will post marking pic
                  • Dinneke
                    • Apr 2014
                    • 154
                    • Netherlands
                    Re: 8030/8039mosfet
                    markings
                    replacing as i wrote
                    • mon2
                      • Dec 2019
                      • 14334
                      Re: 8030/8039mosfet
                      Can you post pics of the bottom side as well?
                      These do not look like mosfets.
                      • Dinneke
                        • Apr 2014
                        • 154
                        • Netherlands
                        Re: 8030/8039mosfet
                        Are mosfets SURE, 8 pins, 4 on one side common and a heatpad connected to Drain
                        Repaced by Sisa18 the N_channel ofcourse
                        • mon2
                          • Dec 2019
                          • 14334
                          Re: 8030/8039mosfet
                          How did you conclude this mosfet is a p-channel ?
                          Never mind..found the datasheet. Indeed it is P-channel. Strange that Toshiba has the same part #, yet N-channel.
                          • Dinneke
                            • Apr 2014
                            • 154
                            • Netherlands
                            Re: 8030/8039mosfet
                            I know how mosfets work....thanks for the datasheet
                            Repair succes
                            • Jane
                              How do you test MOSFET in laptops ?
                              by Jane
                              I tried to use this method:
                              Testing an N-channel MOSFET:
                              Step 1: Discharge the Gate (turn off the MOSFET)
                              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                              Step 2: Charge the Gate (turn on the MOSFET)
                              Now, place the red probe on the Gate (G) and the black probe on the
                              09-27-2024, 03:31 AM
                            • Nooy
                              VGA MOSfet permanently shorted and loss of MOSfet pad
                              by Nooy
                              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                              02-14-2024, 02:26 AM
                            • BlackBeetle
                              MEDION AKOYA S15450 MD 63650 MSN: 30030203
                              by BlackBeetle
                              Hello, I have a problem with a Medion notebook.
                              https://www.medion.com/de/service/pr...etail/30030203
                              MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
                              The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
                              https://community.medion.com/t5/Note.../104097/page/2
                              Bios Version...
                              08-09-2024, 05:50 PM
                            • AppleLover123
                              Asus X712EA 3 volts after the first mosfet
                              by AppleLover123
                              Hey guys,
                              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                              Now i thought something...
                              12-15-2024, 07:49 AM
                            • MicroSMD Lab
                              ASUS ROG Zephyrus GPU Mosfet repeat failure
                              by MicroSMD Lab
                              The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                              I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                              01-10-2024, 06:36 AM
