Please Help. Asus F555U Wont work on new battery.
  • roxboy1984
    • Jan 2022
    • 175
    • South Africa
    I have an Asus F555u that stopped working and i took it to another technician who jumped one of the mosfets as you can see in the pic and the machine now turns on and runs on AC but it wont work on battery at all despite the battery being new.
  • mon2
    • Dec 2019
    • 13849
    Re: Please Help. Asus F555U Wont work on new battery.
    1) Never a good idea to bridge the mosfet for a real fix.
    2) Measure the voltage to ground on pin # 4 of this mosfet pad on the PCB = GATE pin. If working properly, the gate voltage should be ~25 volts.
    3) The mosfet that was bypassed is also a N-channel mosfet. Appears to be the same size as the AON7410 that is on the board. Measure the dimensions of each and compare if that will work for you.
    4) Any suitable / same size mosfet will work (30V or higher rated) but has to be N-channel. Similar or improved current support (ie. Rds should be as low as possible = allows for the same or higher current support as the original mosfet).
    Then test again. If the issue is not fixed, remove all power and check the resistance across the AON7410 mosfet that is onboard and showing in your posted pic.
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    • roxboy1984
      • Jan 2022
      • 175
      • South Africa
      Ok so i measured the voltage to ground from the gate pad as you suggested and it was 0.113V
      I found a replacement MOSFET and im getting 24V on the gate. i tried putting everything back together and all the lights and fans etc spin but now im getting no display. tried external via HDMI and nothing.
      • roxboy1984
        • Jan 2022
        • 175
        • South Africa
        And when i connect the battery it wont switch on at all. as i insert charger the light bulb led flashes and then goes off.
        • mon2
          • Dec 2019
          • 13849
          There are 2 x DCin mosfets between the external power adapter and the main logic board power rail.
          You are working with one of these DCin mosfets.
          Remove the battery as it is not required to boot the logic board.
          Attempt to power up using only the external power adapter. The power adapter should be the recommended unit for this laptop.
          Is your logic board working properly ? If not, power down and double-check your work.
          Meter in resistance mode.
          With no power, also measure the RESISTANCE across the mosfet pins for the other mosfet.
          Post the resistance measurements. With the posted details, the logic board should be able to boot like before but using only the external power adapter but with both of the DCin mosfets installed.
          If the gate voltage of each of these DCin mosfets is ~25 volts (24 is fine), then the mosfet is being told to turn ON. This is correct for using only the external power adapter.
          The use of the battery and battery charge function are other cases to review but this should work as noted / with video, etc. With no power -> carefully double-check your work.
          • roxboy1984
            • Jan 2022
            • 175
            • South Africa
            Ok so i did as you recommended. i replaced the mosfet and i managed to get the machine to work on external power. Then all of a sudden it stopped booting and i lost the 24V on the MOSFET which i think is the reason the other tech jumped the mosfet as it kept doing this. I then removed the mosfet that i had replaced and shorted the pads and the machine came on again. So i then put the MOSFET back on the board the 24V returned.
            • roxboy1984
              • Jan 2022
              • 175
              • South Africa
              Also when i plug in the internal monitor i get backlight but no Asus Logo. If i disconnect internal display and connect external monitor via HDMI i get picture.
              • roxboy1984
                • Jan 2022
                • 175
                • South Africa
                ok disregard the screen issues. there was a short on the LVDS connector on the board so ive sorted that and onboard display is now working.
                • roxboy1984
                  • Jan 2022
                  • 175
                  • South Africa
                  After more troubleshooting this is what ive found. The machine seems to run fine with Mosfet replaced while only on external charger. When the battery is added into the equation it will power up and then randomly shuts off and goes into a boot loop and after a while will no longer boot and now the 24V on the Mosfet is missing and i have to remove the mosfet from the board and return it and then the 24V will return.
                  • mon2
                    • Dec 2019
                    • 13849
                    Review the battery mosfet that should be direct to the battery connector.
                    Remove all power, no battery. Check the resistance across the mosfet pins.
                    Source (1-2-3) and drain (5-6-7-8)
                    Source (1-2-3) and gate (4)
                    Gate (4) and drain (5-6-7-8)
                    Post each measurement.
                    • roxboy1984
                      • Jan 2022
                      • 175
                      • South Africa
                      Thanks so much. Im battling a bit with no Schematic. is this is the battery mosfet in the pic? If so, the measurements are as follows.
                      Source (1-2-3) and drain (5-6-7-8) = 8.1 mega Ohm
                      Source (1-2-3) and gate (4) = OL
                      Gate (4) and drain (5-6-7-8) = 13.5 Mega Ohm
                      in diode mode on this mosfet i get the following also.
                      Source (1-2-3) and drain (5-6-7-8) = 0.47V
                      • mon2
                        • Dec 2019
                        • 13849
                        Mosfet resistance checks are fine.
                        Which charger IC is nearby these mosfets?
                        Post the topside markings on the ic.
                        From this information we can study a typical schematic of the charger IC design. Then we will be able to confirm which mosfet is the battery mosfet.
                        Also, with no power, continue to check the resistance of the other mosfets near the square charger IC. The charger IC will most likely be the BQ charger series from Texas Instruments.
                        • roxboy1984
                          • Jan 2022
                          • 175
                          • South Africa
                          Attached is a pic of the charger IC nearby. Ive attached a pic of the other mosfets around charger IC which ive numbered to correspond to the below readings.
                          Mosfet 1
                          Source (1-2-3) and drain (5-6-7-8) = 4.6 mega Ohm (0.47V on diode mode)
                          Source (1-2-3) and gate (4) = 25.5 Kilo Ohm
                          Gate (4) and drain (5-6-7-8) = 2.64 Mega Ohm
                          Mosfet 2
                          Source (1-2-3) and drain (5-6-7-8) = 7.8 mega Ohm (0.47V on diode mode)
                          Source (1-2-3) and gate (4) = 0.21 Mega Ohm
                          Gate (4) and drain (5-6-7-8) = 6 Mega Ohm
                          Mosfet 3
                          Source (1-2-3) and drain (5-6-7-8) = 43.8 kilo Ohm (0.51V on diode mode)
                          Source (1-2-3) and gate (4) = 1.082 Mega Ohm
                          Gate (4) and drain (5-6-7-8) = 0. 672 Mega Ohm
                          • mon2
                            • Dec 2019
                            • 13849
                            Ok. Charger IC = BQ24780S. Good to know.
                            This IC drives N-channel mosfets so the nearby parts will be N-channel style. That is, the GATE voltage must be HIGHER than the voltage passing through source / drain pins. Often it is ~25 volts for the 2 x DCin mosfets to enable each.
                            Mosfet 1
                            Mosfet 2
                            * ok resistance readings
                            Mosfet 3
                            Above are suspects (shown in RED).
                            Trace the pin # 4 = GATE of the mosfets #1 and # 3. They should be mating with a series resistor = (usually) ~4k. Then trace the other side of the 4k resistor back to the charger IC (BQ24780S). Which pins are being used on the charger IC for these mosfets. This will help us to identify the function of these mosfets.
                            Likely one of these will be mated to the ACDRV pin.
                            PS: Any silk screen markings on the logic board that may help us to locate a schematic or BV file ?
                            • roxboy1984
                              • Jan 2022
                              • 175
                              • South Africa
                              I am battling massively to trace the circuits. Is there any trick to this? It disappears through the board and I lose it. These are the only markings I can find on the board, not sure where else to look for schematics.
                              • mon2
                                • Dec 2019
                                • 13849
                                My apologies. You posted a BV file in your first post. That file is also in my paid database but it does not appear to be accurate. My version of this file does not offer the 2 mosfets you are showing in your posted pic.
                                Have a .fz file with the same version of the board and that appears to be accurate.
                                Noting this, if you select the pin #4 of the same mosfets, you can pin point the charger IC and its function.
                                • mon2
                                  • Dec 2019
                                  • 13849
                                  See attached. These are the 2 x DCin mosfets that need to be investigated.
                                  • roxboy1984
                                    • Jan 2022
                                    • 175
                                    • South Africa
                                    ok i can confirm that Mosfet number 2 in my picture has its gate connected to the pin you illustrated on the charger IC.
                                    As far as the two DC mosfets you mentioned. those seem to be the original ones we looked at in the first post. The one that was missing that previous technician bypassed was PQ8906 which i replaced from a donor board.
                                    • roxboy1984
                                      • Jan 2022
                                      • 175
                                      • South Africa
                                      Ok so i tested PQ8907 and this is what i got.
                                      Source (1-2-3) and drain (5-6-7-8) = 5.6 mega Ohm (0.51V on diode mode)
                                      Source (1-2-3) and gate (4) = 5.1 mega Ohm
                                      Gate (4) and drain (5-6-7-8) = 2.1 Mega Ohm
                                      • mon2
                                        • Dec 2019
                                        • 13849
                                        These are good mosfet resistance readings. Will catch up once at the office.
                                        • dhenion
                                          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                          by dhenion
                                          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                          The original board was:
                                          ASUS X510UNR REV 3.0 A
                                          The replacement board is:
                                          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                          01-30-2024, 01:45 PM
                                        • dhs6512
                                          Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                                          by dhs6512
                                          Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                                          Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                                          Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                                          When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                                          Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                                          When connecting...
                                          10-29-2024, 11:04 AM
                                        • Iherduleikgemz
                                          Asus FX505DY - Battery not charging - BQ24780S
                                          by Iherduleikgemz
                                          Hello everyone
                                          I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                          I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                          01-13-2025, 03:54 PM
                                        • pabloroggeri
                                          Lenovo V310-15ISK - It doesn't work after changing the battery
                                          by pabloroggeri
                                          Good guys. I changed the battery to a Lenovo V310-15ISK.
                                          The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                                          When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                                          08-23-2024, 12:01 PM
                                        • dr.thodt
                                          Asus GA401Q only working from battery
                                          by dr.thodt
                                          I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
                                          The battery status is 255%, also with a brand new battery.
                                          The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
                                          If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
                                          There's a...
                                          12-20-2024, 08:23 AM
