Please Help. Asus F555U Wont work on new battery.
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    Re: Please Help. Asus F555U Wont work on new battery.
    Originally posted by mon2
    These are good mosfet resistance readings. Will catch up once at the office.
    Thanks, Will wait for your feedback. Appreciate it.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Ok. Charger IC = BQ24780S. Good to know.
      Also it's a very common failure point so if the MOSFETs had been previously damaged and bridged I would replace BQ24780S and it is likely that the battery issues will be solved.
      A working TV? How boring!
      • mon2
        • 14685
        Thank you. Please consider to replace the charger IC as suggested above.
        Lots of flux, enough hot air to melt the solder but low pressure so the parts do not go flying. Be patient and apply in circles over the top of the IC. Use tweezers to gently nudge and confirm the ic is able to move in the melted solder.
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          Thankyou both for the help. i will try get a replacement charger IC and see if that resolves the issue. Appreciate the advice.
          • dhenion
            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
            by dhenion
            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
            The original board was:
            ASUS X510UNR REV 3.0 A
            The replacement board is:
            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
            01-30-2024, 01:45 PM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • dhs6512
            Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
            by dhs6512
            Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
            Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
            Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
            When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
            Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
            When connecting...
            10-29-2024, 11:04 AM
          • Iherduleikgemz
            Asus FX505DY - Battery not charging - BQ24780S
            by Iherduleikgemz
            Hello everyone
            I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
            I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
            01-13-2025, 03:54 PM
          • pabloroggeri
            Lenovo V310-15ISK - It doesn't work after changing the battery
            by pabloroggeri
            Good guys. I changed the battery to a Lenovo V310-15ISK.
            The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
            When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
            08-23-2024, 12:01 PM
