Macbook pro a1286 no backlight
  • Instafixx
    • Jul 2022
    • 374
    • India
    I just received a Macbook A1286 from a client with no backlight. The display graphics are visible as seen with a torch. The laptop boots up and chimes.
    The customer says that he had taken it to a shop for software update and post software update the screen went blank.
    There is no sign of corrosion or tampering inside the board.
    Reading on F9700 is 12.2 V.
    Any help would be appreciated
  • mon2
    • Dec 2019
    • 14070
    Re: Macbook pro a1286 no backlight
    What is the 820-xxxx logic board number?
    Link or post the schematic if on this forum.
    Assuming the fuse is the backlight fuse, the boost voltage is not being created. Respectively, the boost regulator has an enable pin. Locate it and check the voltage (with care) to confirm the backlight is being enabled.
    Do you read this voltage on both sides of the fuse?
    Post the reading. Also note that the backlight will only enable if the display is being detected. So, with caution, inspect the LCD connector on the logic board for any damages.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Apologies for not posting the Board Number its 820-3330.
      LCD Connector checked- seems ok.
      Thanks for pointing it out. The Fuse has Voltage only on Pin #1 and not on Pin#2. Working on it and will update soon
      • mon2
        • Dec 2019
        • 14070
        Before replacing the fuse, do measure the resistance to ground on the no voltage side. With no power to the board.
        The fuse blew for a reason. Do not bridge the fuse as it is too risky.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Removed the Fuse and check resistance on #1.
          The reading 450 and on Pin#2 its 850.
          • mon2
            • Dec 2019
            • 14070
            Can you confirm the units of the measurements ?
            Do you mean 450 ohms and 850 ohms ?
            What is the meter scale or can you post a pic of the meter face during these tests?
            The resistance may be ok and not too low.
            Do you have spare fuse from a donor board perhaps ? The rating should be similar so that it does not allow too much current to pass through, if there is a fault.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Yes i mean 450 Ohms.
              I installed another fuse from the donor board but same result.
              There is no voltage on point #3 on Q9706 (LCDBKLT_EN_DIV). Do you think that might be the problem?
              • mon2
                • Dec 2019
                • 14070
                See attached. Post the voltage readings for each.
                The mosfet @ PQ9706 = P-channel mosfet. This needs to be ON for the backlight to work.
                For the P-channel mosfet to work, the GATE voltage needs to be LOWER than the voltage it is passing through source / drain pins.
                For the GATE to be lower, the resistor based voltage divider on the gate pin must be present.
                That is, BOTH mosfets inside of Q9707 must be ON. Only if BOTH of these mosfets are ON, then the resistor based voltage divider will be created - that is the bottom resistor will mate to ground.
                Then if you review a calculator (online), the 12 volts will enter the TOP resistor and the lower resistor will pull down this voltage and in the end, the GATE will be a lower voltage to enable the top mosfet.
                So, we need to know the gate voltage of each Q9707 mosfets to see if they are being enabled or not.
                Update - @ 850 ohms to ground on fuse pin # 2 - someone is leaking. Post your voltage measurements.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  Voltage at Q9707
                  #1 0.5V
                  #2 3.35V
                  #3 10.89V
                  #4 0.4V
                  #5 1.7V
                  #6 0.6V
                  Please guide.
                  • mon2
                    • Dec 2019
                    • 14070
                    1) confirm the voltage on both sides of fuse F9700 again.
                    2) remove all power. Measure the resistance from F9700 to pin #3 of the mosfet Q9707.
                    Post the measurements.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      Voltage on Fuse F9700 (Fuse was Changed)
                      Pin#1 12.56V
                      Pin #2 12.56V
                      Resistance from Fuse to Pin#3 Q9707 is .448.
                      We had to move up the meter to 2M from 2k as it was showing 1 as reading. { Picture Attached}
                      • mon2
                        • Dec 2019
                        • 14070
                        Resistance to pin #3 of the mosfet is fine.
                        With a piece of wire, connect pin # 3 of the mosfet to ground. This bypass will act the same as the 2 x mosfets when they are enabled. That is, the lower resistor will be mated with ground and then the top mosfet should have a lower voltage at the gate to enable the backlight.
                        It is a quick test method.
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          Hello, i did that but no still light on display.
                          Please check out the image of the wire.
                          • mon2
                            • Dec 2019
                            • 14070
                            Measure the voltage on each pin of Q9706.
                            With this short, pin #4 should be a lower voltage and should turn Q9706 ON.
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              All Pins are at 12.57V
                              Pin #3 4.373
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                measure value of that resistor .... looks like it's burned.
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  Hello Resistor R9741 as marked in the Picture
                                  Voltages
                                  #1 0V
                                  #2 0.01V
                                  Resistance (With No Power and Meter Se at 2K)
                                  #1 0 ohms
                                  #2 .504 i.e 505 ohms
                                  • mon2
                                    • Dec 2019
                                    • 14070
                                    R9741 = 10k in the schematic. From the LP8550 datasheet this value may not be critical to the operation but the logic board does not match the schematic value.
                                    Now that the top mosfet is passing through the required voltage, the LP8550 will function provided there are signals on:
                                    I2C_BKL_1_SCL
                                    I2C_BKL_1_SDA
                                    PPBUS_SW_LCDBKLT_PWR
                                    LCD_BKLT_PWM
                                    Measure the voltage of each and post the readings.
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      i mean resistor value from pin 1 to pin 2 (to see if its just looking burned or it is burned actually.
                                      • mon2
                                        • Dec 2019
                                        • 14070
                                        Attached.
                                        • barry101
                                          Apple A1286 Mid 2012 MacBook Pro 820-3330 LCD Backlight issue
                                          by barry101
                                          Hi everyone.
                                          I hope someone has some suggestions on how to proceed with this issue.
                                          I have an Apple A1286 2012 MacBook Pro with 820-3330 Logic board. My customer purchased this from me in full working condition. Unfortunately, it overheated on him due to being left running on his bed.
                                          Investigation showed the LCD Backlight was not working (had a latent image and external monitor worked), the battery was no longer functioning (system couldn't read it or charge it) and the Samsung 850 EVO SSD was dead (not seen by finder or disk utility). Quite the trifecta....
                                          03-24-2022, 03:25 PM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • francescoranchi
                                          MacBook Pro A1909 LCD (no backlight)
                                          by francescoranchi
                                          Hello Everyone,
                                          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                                          I would need just to make sure that what I know/my reasoning is correct:
                                          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                                          - Seller confirmed its a LCD issue, and not an issue with the...
                                          12-04-2023, 06:46 AM
                                        • tommy97
                                          Apple MacBook A2337 - No backlight
                                          by tommy97
                                          Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                                          The laptop was tested with fully working screen.
                                          PP5v_BKLT_A/B 5V
                                          PP5v_BKLT_D 5V
                                          PP5V_S2 5V
                                          PP5V_SW_LCD 0.4V
                                          P5VS2_PWR_EN 1.8V
                                          P5VS2_BST_R 8V
                                          P5VS2_SW 5V
                                          PPBUS_5VS2_VIN 5V
                                          PPVOUT_LCDBKLT - Doesn't short 0V
                                          FP800 - Both sides 12v
                                          BKLT_EN_R & BL_PWR_EN - around 1.8v
                                          LP800 0.014V On both sides (should be 12? / no short)
                                          UC300 & UP800 Replaced...
                                          12-02-2024, 08:26 AM
