Mosfet SM4378 Equivalent
  • Tend0
    E.E.C.S
    • Oct 2021
    • 92
    • Burkina Faso
    Hi guys I have a PC with charge issue I find one mosfet don't work so I don't have it in stock I have mdu1516 my question is can replace SM4378 N-Channel Enhancement Mode MOSFET 30V, 49A by MDU 1516 Single N-channel Trench MOSFET 30V, 47.6A, 9.0m(ohm)?
  • mon2
    • 14597
    Re: Mosfet SM4378 Equivalent
    Yes.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 92
      • Burkina Faso
      Ok thanks
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
      • dreico33
        AON7403 Mosfet Equivalent
        by dreico33
        Hellow guys,
        I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
        Thank you very much.
        11-16-2024, 09:28 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • mohamed mm
        looking for equivalent mosfet for (IR3598MTRPBF)
        by mohamed mm
        I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
        it's for motherboard ram voltage.
        I hope someone can help me.
        Thank you.
        11-01-2023, 07:28 AM
