HP 15-bw049ur LA-E841P UMA Convert
  • Fernon@Repair
    • Jan 2021
    • 31
    • Sri Lanka
    How to convert HP 15-bw049ur LA-E841P UMA
  • Bonzas
    • 471
    • Indonesia
    Re: HP 15-bw049ur LA-E841P UMA Convert
    just remove graphic chip, it work for me.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Removing Graphic coil will also do the job.
      • janaka
        • Dec 2020
        • 35
        • sri lanka
        are there any methods without removing the GPU
        • mon2
          • Dec 2019
          • 14258
          Post #3 = remove the power rail coil (inductor) that powers the GPU.
          • janaka
            • Dec 2020
            • 35
            • sri lanka
            Originally posted by mon2
            Post #3 = Remove the power rail coil (inductor) that powers the GPU.
            is it enough to convert dis to uma....?what about board ID...?
            • mon2
              • Dec 2019
              • 14258
              I am not sure since I am not the author of the suggested post. It is a very quick experiment to remove the inductor. Worth an attempt. Lots of flux and patience and then lift the power inductor. Do cover the nearby parts with aluminum foil or kapton tape so they do not go flying off the board.
              • janaka
                • Dec 2020
                • 35
                • sri lanka
                How to convert HP LA-E841P dis to UMA
                can you tell me how to convert dis to uma of la-e841p
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Have you acted on post#3?
                  • janaka
                    • Dec 2020
                    • 35
                    • sri lanka
                    yes
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Get image for motherboard with graphics and non graphics and try comparing them. I beleive schematic is not available.
                      • maralexbar
                        • Jul 2017
                        • 4
                        • Paraguay
                        I have tried removing the coil from the GPU phase but when doing this the machine does not boot and puts the fan to maximum.
                        I assume that in new models/revisions the GPU is hardcoded in the BIOS for boot.
                        The original problem is that it does not boot with Windows 10 (Artifacts when loading the OS) but it does boot fine with 7/8
                        • Fraheeba
                          • Dec 2018
                          • 9
                          Your problem does not seem to be hardware related, i.e. it's not a mal-functioning GPU, but you have an out-dated BIOS version without support for Windows 10. I have experienced the problem with artefacts you describe with this particular board multiple times, both for UMA and DIS. The HP BIOS update descriptions list explicitly that updates are required to support Windows 10. Try to resolder your coil and update the BIOS, and it should work fine.
