Apple Macbook Air A2337 not charging
  • Blunttag
    • Jun 2022
    • 27
    • australia
    Re: Apple Macbook Air A2337 not charging
    My Hot air station max out at 500c was not able to remove the mosfet
    also borrow a 61W apple charger and the gate was 12V
    what you mean by feed back loop (sorry if dumb question) and what is the current sense resistor? is it R5260
    • Blunttag
      • Jun 2022
      • 27
      • australia
      Not sure if i did it correctly but was not able to find a good location to check the resistance so i went with what was close
      CHGR_CSO_FILT_P C5261 Pin 1 - R5262 pin 1 = 1.4 ohms
      CHGR_CSO_FILT_N C5262 Pin 1 - R5261 Pin 1 = 1.4 ohms
      • mon2
        • Dec 2019
        • 14664
        These are good readings of the current loop circuit.
        See attached.
        What is the voltage of CHGR_AUX_DET with the adapter connected?
        What is the voltage of this signal line when the adapter is removed ?
        • Blunttag
          • Jun 2022
          • 27
          • australia
          Hi
          I assume the battery has to be connected to test this
          Plugged in voltage around 4V +-0.5
          not plugged in Voltage is 0.02V
          Also the USB-C power meter arrive so i can check what it is drawing
          • Blunttag
            • Jun 2022
            • 27
            • australia
            Rechecked the voltages for CHGR_AUX_DET
            adapter connected :5V
            adapter Disconnected:0V
            • Blunttag
              • Jun 2022
              • 27
              • australia
              #26
              I end up returning the laptop to my cousin in a semi working state, I Like to thank mon2 for the help they provided in trying to diagnose the issue and hope that the diagnostic step in the thread help other people who have the same laptop and are having similar issues.
              Thanks for the help and i really appreciate mon2 taking time to help with the issue.
              • drlarsen
                MacBook Air M1 A2337 battery/charging issue
                by drlarsen
                Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                After some hours, the battery status did not improve. Restore via DFU did not help.
                I connected the power adapter to a Kill-a-Watt...
                07-17-2025, 02:35 PM
              • Clarify4082
                by Clarify4082
                I´ve a Macbook Air A2337, it is working but not charging.
                Voltages on the charging adapter:
                1: 183 mV
                2: 183 mV
                3: 3.28 V
                4: 3.29 V
                5: 0 V
                6: 0 V
                7: 0 V
                No signs of liquid damage, both ports and direction same problem......
                05-03-2025, 01:18 PM
              • fisha
                Apple macbook Pro Retina A1398 Battery not charging
                by fisha
                Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
                07-20-2024, 08:39 AM
              • Skrndelj
                Apple Macbook Air M1 A2337 Trackpad problem
                by Skrndelj
                Hello all,
                I am repairing a Macbook A2337 and i have a problem
                The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                I inspected the whole board and everything seems fine.
                Can anyone help me as i didn't fiddle with trackpad...
                06-11-2024, 04:26 AM
                Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View
                Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View...
                10-01-2024, 05:24 AM
