Apple Macbook Air A2337 not charging
  • Blunttag
    • Jun 2022
    • 27
    • australia
    Hi I am not sure if the issue is the battery or something else original the mac book air was not turning on, so i opened it up and removed the battery, the machine turned on without the battery connected so i order a replacement battery, installed it and now the laptop turns on with the cable connected and without the cable connected but it seem to be stuck at 22% with "battery is not charging" i have turned off battery optimized charging and am using the original apple 30W charger USB-C charger.
    Does anyone have an idea what the issue could be?
  • mon2
    • 14663
    Re: Apple Macbook Air A2337 not charging
    30w sounds like a wimpy adapter but this is what was used before to power and charge this laptop?
    Same usb c cable as before when it worked?
    Usb c is able to support power delivery of different power contracts (volts and amps as a pair).
    For the full support of power delivery, the usb c cable should be an Active cable featuring an e-marker chip in the cable head. If the e-marker is defective or missing, then only 5 volts will be used to power the laptop.
    With an active working cable, then up to 20v @ 5A is possible if the source can support it and the load requests it.
    Test with another usb c cable or use a usb c meter to confirm the voltage and current negotiated by the logic board.
    What is the history of this unit? Just started with this fault recently?
    • Blunttag
      • Jun 2022
      • 27
      • australia
      Laptop belongs to my cousin but yes i believe everything was working before and the same USB cable was used, and i tested with a different USB-C charger a HP 65W and the same thing happened plug in turns on but still say not charging and i believe the fault just occurred recently
      • mon2
        • 14663
        Does the 22% value ever decrease as you run from only the battery?
        Link or post the schematic for this logic board if on this forum.
        • Blunttag
          • Jun 2022
          • 27
          • australia
          Yes it does decrease also here is the link to the schematic
          https://www.badcaps.net/forum/showth...ighlight=a2337
          But it won't open in openboardview
          • mon2
            • 14663
            Measure the voltage of each pin of the battery connector J5150 while it is charging. Also while it is not charging.
            Post each measurement.
            • Blunttag
              • Jun 2022
              • 27
              • australia
              Ok measured at the battery connector terminal
              plugged in
              pin 1:11.29V
              pin 2:11.29V
              pin 3:3.26V
              Pin 4:3.26V
              Pin 5: 0V
              Pin 6: 0V
              Pin 7: 0V
              Battery only
              pin 1:11.13V
              pin 2:11.13V
              pin 3:3.26V
              Pin 4:3.26V
              Pin 5: 0V
              Pin 6: 0V
              Pin 7: 0V
              Not sure if this make a difference but i also checked if there was a short on Pin 5 and there is a short to ground on pin 5 while laptop is off
              • mon2
                • 14663
                Measure the voltage on each pin of the battery mosfet Q5625 for each case.
                Source (1-2-3)
                Gate (4)
                Drain (5-6-7-8)
                • Blunttag
                  • Jun 2022
                  • 27
                  • australia
                  Hi do you mean Q5265? as there does not appear to be a Q5625 mosfet
                  • Blunttag
                    • Jun 2022
                    • 27
                    • australia
                    Pin1,2,3 all connected :11.99V
                    Pin4: 12V
                    Pin5: 11.28V
                    • mon2
                      • 14663
                      Yes, my bad. Indeed Q5265.
                      What is the voltage of PPBUS_AON ?
                      For each of these tests, do attach the power adapter.
                      Update:
                      After the above, remove all power & no battery.
                      Meter in resistance mode.
                      Check the resistance across the same Q5265 mosfet:
                      Source (1-2-3) & drain (5-6-7-8)
                      Source (1-2-3) & gate (4)
                      Gate (4) & drain (5-6-7-8)
                      This mosfet is a P-channel mosfet so the gate (pin 4) voltage has to be lower than the voltage it is passing to turn ON.
                      What is not known yet is if the ISL9240 is enabling this mosfet or is this mosfet defective.
                      After the resistance check, we will know more.
                      • Blunttag
                        • Jun 2022
                        • 27
                        • australia
                        PPBUS_AON:11.99V
                        Source (1-2-3) & drain (5-6-7-8) :100K Ohms
                        Source (1-2-3) & gate (4) : 15M Ohms
                        Gate (4) & drain (5-6-7-8) : 15M Ohms
                        • mon2
                          • 14663
                          The source and drain resistance readings are considered low for mosfets.
                          If you are comfortable with it and have the tools and flux, remove this mosfet Q5265 off the board. Then perform the same measurements while the mosfet is on your table. Do allow the mosfet to cool down before checking the readings. Be patient in removing the mosfet with low air pressure so other parts do not go flying.
                          When this mosfet is off the board, attach the battery and adapter. Check if the gate pad pin on the pcb is with a different voltage than before.
                          Reference:
                          http://electronicsbeliever.com/how-t...0good%20MOSFET.
                          • mon2
                            • 14663
                            Another idea..
                            Disconnect the battery.
                            Attach the power adapter. What is the voltage on the battery connector? That is, does the voltage from the adapter appear on the battery connector?
                            • Blunttag
                              • Jun 2022
                              • 27
                              • australia
                              With battery disconnected
                              Pin 1:11.99V
                              Pin 2:11.99V
                              Pin 3: 3.26V
                              Pin 4: 3.26V
                              Pin 5: 0V
                              Pin 6: 0V
                              Pin 7: 0V
                              don't have a USB-C power meter (ordered one waiting for arrival) so don't know what come from the adapter
                              • mon2
                                • 14663
                                Ok. What is the gate voltage on the mosfet from the last test?
                                No battery, only adapter.
                                • Blunttag
                                  • Jun 2022
                                  • 27
                                  • australia
                                  Gate voltage is 3.69V with battery disconnected
                                  • mon2
                                    • 14663
                                    That is a good gate voltage to turn ON this P-channel mosfet.
                                    If you have the tools, remove this mosfet and measure it's resistance when it is out of circuit.
                                    • Blunttag
                                      • Jun 2022
                                      • 27
                                      • australia
                                      Having difficult removing it what the max safe temp i can use?
                                      Atm i'm at 400'c for 20sec and its not budging with flux also on it.
                                      Tested on a Practice board and the SMD came off is the solder on Apple board require a high temp to remove?
                                      Also rechecked Source (1-2-3) & drain (5-6-7-8) with a different Multi meter and getting 10M + Ohms
                                      • mon2
                                        • 14663
                                        Hi.
                                        1) wait on other feedback before proceeding if the resistance is higher on the source/drain pins.
                                        2) concern is that when the battery is attached, this mosfet is OFF as the gate voltage is high.
                                        3) yes, the mosfet may require higher heat. We use 550c on our Best 863 which is a clone of the Quick models but the true temp at the tip maybe a different value than 550C. That is, higher than 400C for sure. Lots of flux and keep rotating in a circle till melted.
                                        However the resistance is ok with your other meter.
                                        Wait on additional feedback.
                                        Also suggest to use a higher power adapter and check the gate voltage again. Any brand is ok but 60w or more.
                                        4) remove all power and check the resistance of the current feedback loop.
                                        Check the resistance from CHGR_CSO_FILT_P to the current sense resistor.
                                        Then CHGR_CSO_FILT_N to the same resistor.
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
                                        • Clarify4082
                                          by Clarify4082
                                          I´ve a Macbook Air A2337, it is working but not charging.
                                          Voltages on the charging adapter:
                                          1: 183 mV
                                          2: 183 mV
                                          3: 3.28 V
                                          4: 3.29 V
                                          5: 0 V
                                          6: 0 V
                                          7: 0 V
                                          No signs of liquid damage, both ports and direction same problem......
                                          05-03-2025, 01:18 PM
                                        • fisha
                                          Apple macbook Pro Retina A1398 Battery not charging
                                          by fisha
                                          Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
                                          07-20-2024, 08:39 AM
                                        • Skrndelj
                                          Apple Macbook Air M1 A2337 Trackpad problem
                                          by Skrndelj
                                          Hello all,
                                          I am repairing a Macbook A2337 and i have a problem
                                          The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                                          When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                                          I inspected the whole board and everything seems fine.
                                          Can anyone help me as i didn't fiddle with trackpad...
                                          06-11-2024, 04:26 AM
                                          Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View
                                          Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View...
                                          10-01-2024, 05:24 AM
