BQ24735 - faulty?
  • Jane
    • Aug 2010
    • 188
    Re: BQ24735 - faulty?
    Thank you for your replies
    @mon2
    There is not blob. JP 8805 is as a path on PCB. I would have to cut the path on PCB to divide JP8805.
    Tomorrow I will check the surroundings of Q8805.
    Yes, I have a variable power supply. How to use it in the best way in this case properly?
    Sephir0th:
    what current should I use if injecting voltage? Voltage 19V?
    Thank you for help
    • mon2
      • Dec 2019
      • 14631
      Never this high a voltage!! Always recommend to use a voltage lower or equal to the lowest voltage on the logic board.
      We use 0v7 = 0.7 volts with our SHORT KILLER tool which can pulse out 30A of current. It worked to fix a macbook yesterday within minutes of being dropped off to our shop. With a thermal camera, lit up the tantalum cap like a Christmas tree. Could smell the defective cap which cracked up like popcorn.
      Still suggest to review the board and use injection as a last resort.
      What is the exact resistance to ground in ohms ? Use the lowest scale on your meter. Very possible that you have a shorted cap but we still need to keep the voltage LOW - in case that the same voltage travels to the CPU rail due to a defective high side mosfet that may be leaking. That is, what you apply here will reach the CPU and absolutely kill the component.
      • Jane
        • Aug 2010
        • 188
        There is 1.3 Ohm short to ground
        Do you mean I should use 0.7V and as many Amps I can set on my laboratory power supply until those 30Apms?
        I also tried to find out and check Q8804 as you suggested yesterday. Unfortunatelly I do not have a boardview and PCB is not described well - marking each part - so it is quite hard to find out a particular part. But if there were any short in cappacitors around that Q8804 also a drain of that Q8804 woud have to be in short, I think
        But there is no other mosfet( I find) that is in short - except Q8802 ( after not being able to desolder JP 8805 because it is connected as a path on PCB.)
        Is it a time for voltage injection now?
        Thank you for help
        • mon2
          • Dec 2019
          • 14631
          Can you post a few pics of your board?
          The mosfets should be simple to locate. We know the gate pins are driven by the charger IC. Place your meter in DIODE mode. Remove all power to the logic board.
          Short the meter probes and confirm the tone.
          Now one probe on gate pin #4 as an example. Other meter probe to a nearby resistor. Do you hear a tone? No? Skip to another resistor till you do.
          After finding the resistor, switch to the other side of the resistor. Other meter probe now direct to the charger IC.
          • Jane
            • Aug 2010
            • 188
            Here are some pictures of mainboard.
            Both top and bottom sides have two pictures
            Part1-a.jpg shows part where BQ24735 is and Part1-b.jpg is the opposite side where mosfets are.
            Part1-b.jpg is the other part of side where BQ24735 is and Part2-b.jpg is the other part where mosfets are .
            IN red ink I made few notes there
            Thank you for advice how to continue with the repair.
            • Jane
              • Aug 2010
              • 188
              #26
              BQ24735 - still probem with it
              I try to repair laptop ACER SWIFT SF314-51 , which is dead.
              I found out there is a problem with BQ24735 - ACDRV (pin 4) is only about 0.9V. ( if i remove resistor - coming from that ACDRV to mosfet, value is still not good).
              Few others values of BQ24735 are:
              Values are about :
              pin 20: VCC 19V
              pin 6: ACDET 2.6V
              pin 16: REGN 5.99V
              pin 5: ACOK 1.6V
              When I remove pull up resistor from pin 5 ( ACOK) value becomes about 3.3V.
              Do you think that there must be a problem after that pull up resistor rail, so that the voltage from ACOK is pull down not pull up?
              I tried 3 different BQ24735 but the results still not good
              Laptop schematic included.
              Any help would be appreciated.
              • mon2
                • Dec 2019
                • 14631
                Re: BQ24735 - still probem with it
                Leave the ACDRV resistor off till the voltage is boosted.
                Apply flux and reflow the charger IC till the ic swims back into the proper alignment on the smd pads. Then gently push from the corner with tweezers till the ic moves away a small amount and let go. All while blowing with hot air. The ic will bounce back, naturally. The pads are likely shorting under the charger IC.
                Check the ACDRV pin voltage again. Other voltages are fine. ACOK is open drain and requires a pull up resistor to define the logic high status. For now, review the ACDRV pin.
                • Repairman851
                  • Feb 2017
                  • Turkiye
                  #28
                  Hi Jane,
                  It is an old post but I have the same problem today. It is another Acer mobo but uses the same BQ24735 power controller IC. Wd you be so kind and reply if you did find the cause of the problem and remedies, if any.. Rgds
                  • Jane
                    • Aug 2010
                    • 188
                    #29
                    As far as I remember I did NOT solve the problem.
                    • rumpumpel1
                      • Jul 2019
                      • 160
                      • germany
                      #30
                      a comment about measuring AC-DRV: this is a PWM signal. Depending upon the duty cycle a multimeter will show much less, than the effective voltage. If you want to check AC_DRV use an oscilloscope.
                      • Jane
                        • Aug 2010
                        • 188
                        #31
                        It might be an interesting point about PWM, but how much different the value will be ( if using multimeter)?
                        • mon2
                          • Dec 2019
                          • 14631
                          If still stuck, carefully measure each pin on this BQ charger IC and post in a table with their pin # + pin labels.
                          The ACDRV must be a boosted value of ~25v as long as the conditions for the BQ charger IC are met. This includes CMSRC; REGN; VCC to this charger IC; ACDET.
                          ACDRV voltage = adapter voltage + REGN if the above conditions are met.
                          • rumpumpel1
                            • Jul 2019
                            • 160
                            • germany
                            #33
                            example: if there is no battery a duty cycle of 50% might be sufficient and a multimeter shows roughly 12V for ACDRV.
                            • ndarjo21
                              • Nov 2021
                              • 81
                              • Indonesia
                              #34
                              hi mon2, if VCC 18.8v, ACDET 2.8v, but the REGN is 12.2v, and AC drive is 0v. no shorted in the each pin of the IC except ground. is that normal? the REGN? BTST is 12.39v. the diode between BTST and REGN is normal.
                              • mon2
                                • Dec 2019
                                • 14631
                                No, not normal. REGN is a ldo output and should be ~6v. Remove for now the series 4k ohm resistor at the output of acdrv. Do not lose this part. Confirm that the BQ ic regn pin is not shorted to another pin on the device. Flux and reflow the BQ part if necessary with low air pressure to avoid loss of tiny parts. The BQ chip may be defective.
                                • ndarjo21
                                  • Nov 2021
                                  • 81
                                  • Indonesia
                                  #36
                                  thanks mon2
                                  • estebanpe
                                    asus x541sa no power (bq24735) no ACDRV
                                    by estebanpe
                                    Hello, I have this board that drives me crazy, I can't activate the input mosfets, I have changed the bq24735 with the same result
                                    These are the IC voltages and I also leave a couple of voltages extra
                                    1 3.9v
                                    2 3.9v
                                    3 0v
                                    4 0.03v
                                    5 0.05v
                                    6 2.6v
                                    7 0.004v
                                    8 0.020v
                                    9 0.020v
                                    10 0.15v
                                    11 3.13v
                                    12 3.10v
                                    13 3.11vv
                                    14 0v
                                    15 0v
                                    16 6v
                                    17 5.8v
                                    18 3.10v
                                    19 3.10v
                                    20 19v
                                    P_CHG_AC_GATE_20 0.010v
                                    AC_BAT_SYS 3.4v​
                                    10-15-2024, 05:23 AM
                                  • proxneo
                                    Recapping Sony ICF-SW55 - verifying cap values
                                    by proxneo
                                    Dear reader
                                    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                    At the moment, I have selected replacements based on the following list of values:
                                    3 x 470uF 10VDC
                                    3 x 4.7uF 35VDC
                                    4 x 47uF 50VDC
                                    8 x 22uF 6.3 VDC
                                    1 x 220uF 6.3VDC
                                    5 x 100uF 6.3VDC
                                    Which...
                                    06-21-2023, 12:38 AM
                                  • rashidjafar
                                    Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                                    by rashidjafar
                                    I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                                    Values for :-
                                    PC43 : Capacitor [3x1.5mm]
                                    PL7 : Inductor [2x1mm]
                                    PC39 : Capacitor [1x0.5mm]
                                    Any ideas would be appreciated.
                                    I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                                    08-07-2025, 05:10 PM
                                  • mkdj
                                    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                    by mkdj
                                    About me, my goal and the equipment I (don't) have:
                                    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                    About my issue and my goal:
                                    A friend of mine has a MacBook Air M1 A2337 that does not...
                                    04-03-2025, 08:28 AM
                                  • Kobok
                                    Different (lower) resistor values on PCB?
                                    by Kobok
                                    Dear Alls,
                                    For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                                    09-19-2022, 07:30 AM
