Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help!!
  • roxboy1984
    • Jan 2022
    • 179
    • South Africa
    #61
    Re: Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help
    sorry to ground i got 49.5 Kilo Ohms. the ).320 Mega ohms is to the pin 3
    • mon2
      • Dec 2019
      • 14761
      Resistance with PD1 installed is ok. There is no short condition with PD1 installed. Sometimes, when a transient occurs, devices like PD1 and PD2 will get killed to prevent further damage downstream on the signal pins. This event causes a short circuit condition on the same signal line.
      It appears that you may have a broken trace from the pull-up resistor which is showing 3v3 on the signal trace but this same voltage does not appear at the SMBUS DATA pin on the battery connector.
      Review that one side of the R182 is connected directly to +3v3. That is NOT the side of interest. It is the other side of R182 we need to mate with the pin #3 of the battery connector or even at PD1 since they are all supposed to be on the same trace.
      Let me review that this is correct and then will suggest to use a piece of wire to bridge what may be a broken trace between the 2 points of interest.
      • mon2
        • Dec 2019
        • 14761
        Also, check the voltage @ PR13 = MBDATA. This resistor should also be @ 3v3 (same voltage as on R182).
        Suspecting that you have a broken PCB trace.
        • roxboy1984
          • Jan 2022
          • 179
          • South Africa
          #64
          Ok so i just checked pin 3 again while AC is connected im getting 0.597V and then when i connect the battery i get 0.025V.
          • mon2
            • Dec 2019
            • 14761
            Check the voltage @ PR13 which is the same trace of interest for MBDATA.
            • roxboy1984
              • Jan 2022
              • 179
              • South Africa
              #66
              If I probe PR13 I get 0.47V.
              • mon2
                • Dec 2019
                • 14761
                Same incorrect voltage.
                Remove all power. Check the resistance from PR13 to pin #3 of the battery connector.
                • roxboy1984
                  • Jan 2022
                  • 179
                  • South Africa
                  #68
                  Just to confirm circled in red on the pic im probing the correct point. but from here to pin 3 i get 0.328 Kilo Ohms
                  • mon2
                    • Dec 2019
                    • 14761
                    See attached. PR13 is the large PCB pad that is acting like a jumper. This is MBDATA signal that travels also to the battery connector, pin # 3.
                    Remove all power. Check the resistance from this large PCB pad to pin #3 on the battery connector. What is the resistance ?
                    Next, repeat but from this pad to pin #8 on the nearby charger IC ('BQ' part).
                    What is the resistance ? For each measurement, the resistance should be ~0 ohms.
                    • roxboy1984
                      • Jan 2022
                      • 179
                      • South Africa
                      #70
                      The Pad itself seems to have some kind of coating on it and i cant get a reading. is that little ball i circled not on the same track?
                      • mon2
                        • Dec 2019
                        • 14761
                        Perhaps - place one meter probe there and the other onto pin # 8 of the charger IC to confirm. This is important to probe and check the proper pad / pins. No power during these tests. If the pad is truly correct, the resistance to the BQ charger IC should be 0 ohms.
                        Then check again to the battery connector, pin # 3.
                        Just attached a location for pin #8 on the BQ chip.
                        Each side of this QFN (quad flat pack package) has 5 pins, so locate the 8th pin as per attachment.
                        • roxboy1984
                          • Jan 2022
                          • 179
                          • South Africa
                          #72
                          ok so charger IC pin 8 to pin 3 i get 0.328 Kilo ohms.
                          that little ball of solder to pin 8 is 0 ohms.
                          • mon2
                            • Dec 2019
                            • 14761
                            Ok. One more check - the resistance that you are measuring must be the 330 ohms resistor @ PR1. Double-check as per attachment.
                            From PD1 to pin # 3 on the same battery connector - still ~ 0.328kohms = 328 ohms ?
                            • mon2
                              • Dec 2019
                              • 14761
                              In post #57 you mentioned
                              resistance from R182 to pin 3 i get 0.320 Mega Ohms
                              Did you mean 0.320 kohms = 320 ohms ? That is ok due to resistor PR1 (330 ohms). Can you confirm this again ?
                              Also, if you see a voltage on BOTH sides of R182 then this voltage has to appear at PR13 pad = pin # 8 on the charger IC = pin # 3 on the battery connector.
                              Check again.
                              • roxboy1984
                                • Jan 2022
                                • 179
                                • South Africa
                                #75
                                Not sure which side to measure of PD1 to pin 3 but on one side i get 0.328Kilo Ohms and on the other side of it i get 0.257 Mega ohms.
                                Did you mean 0.320 kohms = 320 ohms ? That is ok due to resistor PR1 (330 ohms). Can you confirm this again ? Definitely 0.330 Mega Ohms
                                • mon2
                                  • Dec 2019
                                  • 14761
                                  Ok. Just asking to get a visual of where the broken trace is on the logic board.
                                  What is the resistance from pin # 8 of the charger IC (BQ) to the pull-up resistor @ R182?
                                  • roxboy1984
                                    • Jan 2022
                                    • 179
                                    • South Africa
                                    #77
                                    Voltage on both side of R182. voltage is 0.437V at PR13 pad
                                    • roxboy1984
                                      • Jan 2022
                                      • 179
                                      • South Africa
                                      #78
                                      0.322 Mega Ohms from R182 to pin 8
                                      • mon2
                                        • Dec 2019
                                        • 14761
                                        See attached. Confirm the resistance between the 2 green arrows = 0 ohms.
                                        This is the pull-up voltage to 3v3.
                                        The MBDATA is on the LEFT side of R182. We need to be sure of this detail.
                                        • roxboy1984
                                          • Jan 2022
                                          • 179
                                          • South Africa
                                          #80
                                          Correct. it is 0 ohms between those points.
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
