Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help!!
  • mon2
    • Dec 2019
    • 14747
    Re: Hp 15-P104NI Laptop switches off with new Battery when AC unplugged!! Please help
    I think that both PQ36 and PQ37 are suspects.
    Remove PQ36 with flux, heat, low air pressure and patience. This is the high side mosfet used to charge the battery. It may be leaking.
    With enough charge on the battery, test again but with PQ36 removed.
    Does the logic board boot ok now with the battery installed ?
    Next, attach the external power adapter with the battery still installed. Boots like normal?
    PQ37 may also be required to be removed. This is the low side mosfet of the charger.
    • roxboy1984
      • Jan 2022
      • 179
      • South Africa
      Thanks so much, I was in the middle of doing what you suggested and my dam hot air gun element packed up. And my soldering iron ceramic core cracked shortly before so I'm waiting on a new rework station before I can continue. FML!!
      • xiongyang
        • Oct 2022
        • 3
        • CHINA
        首先要确定电池和kbc还有充电芯片的通讯是正常的
        First of all, make sure that the communication between the battery and the kbc and the charging chip is normal
        • roxboy1984
          • Jan 2022
          • 179
          • South Africa
          Ok so i removed PQ36 as you suggested and there was no change. I spoke to someone else who suggested that PQ39 might be the culprit for switching between battery. what are your thoughts? @mon2?
          • mon2
            • Dec 2019
            • 14747
            Certainly do test the mosfet @ PQ39. This is the battery mosfet that enables / disables, varying on if the adapter is connected. When the adapter is connected, this mosfet should remain OFF and vice-versa if only the battery is used.
            If the mosfet is leaking then yes, could be an issue.
            Remove all power / no battery. Meter in resistance mode.
            Check the resistance across the mosfet pins like before:
            source & drain
            source & gate
            gate & drain
            post each measurement.
            • roxboy1984
              • Jan 2022
              • 179
              • South Africa
              #26
              source & drain
              source & gate
              gate & drain
              Ok so i have done the following. I removed PQ36 and tested without it on only battery and no change.
              I then swopped out PQ39 and no change there either. here are the results of PQ39 with the swopped MOSFET.
              source & drain = 8.23 Kiloohms
              source & gate = 2.34 Megaohms
              gate & drain = 2.65 Megaohms
              • mon2
                • Dec 2019
                • 14747
                If you have removed PQ36 and with battery only, then the battery will not be able to power the logic board. Was this the result you saw during this test?
                This is since the battery power path has been removed when this mosfet was removed.
                Respectively, attach the adapter and the adapter should be able to power the logic board normally (with PQ36 missing). Please confirm.
                This is a bad reading - it is too low for a mosfet - can you confirm the measurement? However, the reading may be influenced by some other component on the logic board.
                • roxboy1984
                  • Jan 2022
                  • 179
                  • South Africa
                  #28
                  Ok so i removed PQ39 to test without any influence of other components and here are the readings.
                  source & drain = 20.4 Kiloohms
                  source & gate = OL
                  gate & drain = 2.34 Megaohms
                  • mon2
                    • Dec 2019
                    • 14747
                    This is a very low resistance for a mosfet. It is defective and must be replaced.
                    • roxboy1984
                      • Jan 2022
                      • 179
                      • South Africa
                      #30
                      Ok, so im not sure what im doing wrong here but as you can see in the attached pics if i measure from source to drain i get different readings depending on where i probe. taking the below readings into account is it still too low? or do you think this mosfet is defective?
                      • mon2
                        • Dec 2019
                        • 14747
                        Review the mosfet test methods here:
                        https://www.homemade-circuits.com/ho...using-digital/
                        You will use the diode mode of your multimeter. One one orientation of the probes, the meter should conduct. Block when the probes are reversed.
                        Post your measurements.
                        The diode mode is 2 clicks to the right on your meter face.
                        • roxboy1984
                          • Jan 2022
                          • 179
                          • South Africa
                          #32
                          Ok so i did as you recommended, thanks for the info.
                          So when i measured from source to drain i got OL as it suggested and then when i moved red probe to gate momentarily and back to drain the numbers start counting up and then i get OL again. if i repeat the steps this continues.
                          • roxboy1984
                            • Jan 2022
                            • 179
                            • South Africa
                            #33
                            As you suggested ive removed PQ36 and the laptop still does the same. It wont power on with just battery connected and then when i connect AC as well as battery it takes forever to power on but it eventually comes on. with battery removed it powers on much faster.
                            • roxboy1984
                              • Jan 2022
                              • 179
                              • South Africa
                              #34
                              do you perhaps have any further ideas based on the findings listed??
                              1.So when i measured from source to drain i got OL as it suggested and then when i moved red probe to gate momentarily and back to drain the numbers start counting up and then i get OL again. if i repeat the steps this continues.
                              2. As you suggested ive removed PQ36 and the laptop still does the same. It wont power on with just battery connected and then when i connect AC as well as battery it takes forever to power on but it eventually comes on. with battery removed it powers on much faster.
                              • mon2
                                • Dec 2019
                                • 14747
                                Remove the adapter & attach only the battery (with some charge).
                                Measure the voltage directly on the battery.
                                Then measure the voltage on the main logic board power rail.
                                Do you read a voltage with only the battery? You should not since the battery mosfet (PQ36) is removed.
                                • roxboy1984
                                  • Jan 2022
                                  • 179
                                  • South Africa
                                  #36
                                  Ok so i measured the voltage on the battery and im getting nothing. im also getting no power on the main power rail.
                                  • mon2
                                    • Dec 2019
                                    • 14747
                                    If the battery is out of circuit and on your work bench - do you read any voltage on the battery connector? You will have to locate the + and - (ground / black probe on your meter) to confirm.
                                    Specifically, does the battery you are using even have a charge and it appears to be dead once you attach it to the logic board ?
                                    Without the battery - does the logic board power up with only the adapter like normal? It should.
                                    • roxboy1984
                                      • Jan 2022
                                      • 179
                                      • South Africa
                                      #38
                                      So with the battery out i tried to measure if there was any charge but from what i read you cant just measure on the positive and negative. i did that and i got nothing. Battery has some protection built in to prevent this.
                                      I also tried with battery connected and then connected AC and the LED went from white to amber to showing that it was charging the battery. Board powers on absolutely fine without the battery installed and only on AC.
                                      PQ36 is now back on the board.
                                      • mon2
                                        • Dec 2019
                                        • 14747
                                        So, now the battery is charging ? Leave it for a while to see if the battery is able to charge enough to power this board since PQ36 is back onboard. For the charging voltage, the high and low side mosfets need to be working to dial up the voltage required for the charging cycle.
                                        • roxboy1984
                                          • Jan 2022
                                          • 179
                                          • South Africa
                                          #40
                                          Well when i say its charging, the battery led indicates the battery is charging based on the amber color. but it has been doing this from the beginning. as soon as i remove the AC it doesnt switch over to battery. but i shall leave it for a while and try it again to make sure.
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            by sam_sam_sam
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
                                            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                            by sam_sam_sam
                                            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                            So I have put them on the battery testing machine to drain each battery cell down to...
                                            09-04-2022, 04:45 PM
