Asus X555LD ver 3.6 no power
  • Ariu
    • Dec 2020
    • 133
    Hello, I'm having issues with this Notebook, it doesn't power on.All voltages are present, 5v & 3v and no short at any coils.
    It consumes 56 mA when is connected to the power supply and when power button pressed drops to 2mA.
    I have already found a same problem that someone posted in YouTube but I don't understand the language.
    Can anyone translate it please or give me any suggestions?
  • mon2
    • Dec 2019
    • 14106
    Re: Asus X555LD ver 3.6 no power
    Link the youtube video.
    • Ariu
      • Dec 2020
      • 133
      https://m.youtube.com/watch?v=yQ7JQsHJdkE
      • mon2
        • Dec 2019
        • 14106
        I am unable to pick up all of the words of this slang.
        But the actions appear to be:
        1) check the 3*ferrite bead inductors. Are they ok or burnt on your logic board?
        2) he appears to reflash the bios chip he shows in the video. Wait on this step and advice from others.
        update:
        see post # 5 for a clear bios dump (only if required but be sure to backup your original if you proceed)
        https://www.badcaps.net/forum/showth...ghlight=X555LD
        3) believe you are requesting the mosfet question in the post on youtube? Carefully measure the voltage of each pin on the 2*mosfets that follow the 3* inductors on the board.
        Interested in the voltage on:
        Source (1-2-3)
        Gate (4)
        Drain (5-6-7-8)
        Of each mosfet.
        3) what are top side markings of each mosfet?
        4) near these mosfets will be the charger IC. What are the top side markings of the charger IC?
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • PantherDave
          by PantherDave
          Hi all!
          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
        • conghuyms
          Request for Help – ASUS G531GW Rev 1.6 – No Power On
          by conghuyms
          I need your support with an ASUS G531GW Rev 1.6 laptop.
          When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
          Here’s what I’ve checked so far:
          • Motherboard has been removed for inspection.
          • 3V and 5V always-on rails are present (3V/5V_ALW).
          • 1.8V and 1.09V at the PCH are present.
          • I don’t have the boardview/schematic, so troubleshooting is limited.
          • I tried checking the power button signal from the
          07-20-2025, 09:14 PM
