hp 450 g5
  • ameerrrr
    • Aug 2015
    • 42
    • syria
    hp 450 g5
    My HP Probook 450 G5 keeps turning on by itself after I shut the laptop down.
    Tried several BIOS versions and still the same problem
    Even when the charger is connected or the charger is removed, the laptop works immediately and there is no hard drive, keyboard or anything but the charging jack.
    But when I removed the wireless card, the problem was solved, and when I replaced a laptop with another card, the problem returned
  • mon2
    • 14659
    Re: hp 450 g5
    Post more details of the wifi card and model you are testing.
    The issue maybe the pin #1 = WAKE# line of the adapter.
    To test, apply a thin piece of tape onto pin #1 of the gold contact of the wifi card to mask the contact. Then test again.
    If this line is LOW, the logic board will wake up.
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
    • dellxps15
      macbook 820-00163no sleep wake problem
      by dellxps15
      hi got this board with a burned hole in the vram zone. owner reflower gpu and cpu for no reason ( he watched online video and think that this method will fix every problem). after find gpu totally shorted, i decided to make it uma.
      after send it back to owner he told me board was crashing, so i replaced also the 3 cpu mosfet, telling him that if that doesnt fix the crash, i give up on the repair.
      after replace the 3 mosfet, board was shutting down while loading os, and after asking owner if battery was ok and he told me it was.... i discovered that with another battery pc was booting...
      04-02-2023, 04:36 AM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
