71R-H14BW6-T830, clock stops when shutdown
  • Fontana
    • May 2017
    • 17
    • Brasil
    Hi!
    Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
    The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
    I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
    I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
    Any suggestions?
    OBS: when the pc is off, the clock STOPS, it doesn't reset. When turned on again, it starts counting time normally (with the clock now starting from where it was when it was turned off). I thought of just setting up a script to resync time on logon but I rather use that as a last resort.
  • mon2
    • Dec 2019
    • 14558
    Re: 71R-H14BW6-T830, clock stops when shutdown
    Check the voltage at D11, pin #3 (+3.3VA_RTC).
    What is the voltage when powered ON?
    What is the voltage when powered OFF?
    This is a dual common cathode diode that will select the higher of the 2 input voltages.
    When the power supply is OFF, the RTC should be powered from the diode leg #1 connected to the battery.
    • Fontana
      • May 2017
      • 17
      • Brasil
      DC plugged, machine turned off, 2.87V (3.08V on pin2)
      DC off, 2.85V (2.98V on pin1)
      Sorry, forgot to mention I had tested the diode already.
      Also, SRTC_RST# after R407 is 2.8V
      • mon2
        • Dec 2019
        • 14558
        Is the crystal @ Y6 a known good crystal ? Should be 32.768khz which are very common for RTC circuits.
        • Fontana
          • May 2017
          • 17
          • Brasil
          I have no way to measure it, but it should be fine. I removed it from a board of the same exact same model which problem wasnt related. unless I broke it when replacing but I doubt it. I used heat from bottom of the board to remove it and soldered it back with unleaded.
          • mon2
            • Dec 2019
            • 14558
            What is the voltage @ RTC_TEST# ? (C463 & R406)
            Remove all power -> meter in resistance mode. Check the resistance to ground on each side of the same crystal (Y6).
            This clock crystal is not very critical and can be tested with the same frequency of component from other boards - even different packages.
            • Fontana
              • May 2017
              • 17
              • Brasil
              2.8V
              more than the meter can measure, but this is also the case in a known good board that I have. in diode mode .9V drop
              • mon2
                • Dec 2019
                • 14558
                Reflash the BIOS to the latest if you have not done so already. Just in case there is some s/w fault linked to the RTC. Otherwise, the checks you have performed look good to me.
                • Fontana
                  • May 2017
                  • 17
                  • Brasil
                  I have, but since I have a working board I'll try replacing the bios chip altogether. will try another crystal as well for peace of mind.
                  but if that doesnt fix the problem what can it be? the cpu?
                  • Fontana
                    • May 2017
                    • 17
                    • Brasil
                    replaced bios and ec rom chips. replaced crystal again. no luck
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • shelby5041
                      clock radio / radio lifespan?
                      by shelby5041
                      hi
                      ive got a modern digital clock radio approx 15yrs old
                      my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                      since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                      the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                      it uses very little power just a few watts i would imagine that may have something...
                      09-14-2024, 03:30 AM
                    • kacangpolo
                      Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                      by kacangpolo
                      I have problem with my laptop, with code board X415EA 2.0,
                      laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                      I did :
                      1. Flash Bios
                      2. RTC_RST 3.3V
                      3. LID_SW 3.3V
                      4. WLAN_WAKE# 3.3V
                      08-26-2025, 04:42 AM
                    • UserXP
                      Vintage SONY Digital Clock Radio ICF-C12W no audio
                      by UserXP
                      Dear all,
                      I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                      i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                      My question is, do you know of this brand of capacitors and how bad are...
                      07-21-2025, 08:35 AM
                    • SluggerB
                      XBox cannot be turned off?
                      by SluggerB
                      So a buddy of mine gave me his OG xbox which was having issues. It suffered from the failed clock capacitor issue, the capacitor had leaked on the board. He opened it up and pulled it off with a pair of pliers. After that, he said he couldn't turn the xBox off so I asked if I could try my hand at it
                      I ordered up a spare clock capacitor, opened up the xBox and there was a lot of corrosion and damage near the old capacitor location. I cleaned it all up with IPA, and check for continuity between all the components in the area, including through the vias on the board, and everything...
                      01-29-2022, 06:25 PM
