Dell XPS 9570 no USB-C power
  • kuba2102
    • Jan 2020
    • 45
    • Scotland
    Dell XPS 9570 LA-G341P rev. 1.0
    Hi. I'm having trouble getting the USB-C to work. There's sound when connecting a devices, but no voltage appears on the +VBUS_1 line and only 5v shows up when connecting a charger. The board was after a slight water damage but nowhere near the USB-C port or its components. Apart from water damage the board was 'attacked' with a screwdriver by previous technician, few capacitors were missing from PCH and PQ227, which is 702-5 missing and got it replaced with 702-C that is responsible for DCI detect, not 100% sure if that's the right replacement but seems to work. I'm stuck. thanks
    N124730527 0.7V
    N124539694 0.8V
    N124494892 0.8V
    PD_VDDIO_VIN_3V3 3.3V
    PD_EE_DO 3.3V
    PD_EE_CS# 3.3V
    TBTA_I2C_INT 3.3V
    TBTA_LDO_BMC 0V
    TBT_I2C_DATA_R 3.3
    TBT_I2C_CLK_R 3.3
    VCC1V8A_TBTA_LDO 1.8
    VCC1V8D_TBTA_LDO 1.8
    VCC3V3_FLASH 3.3
    VCC5V0_SYS 5V
  • mon2
    • 14685
    Re: Dell XPS 9570 no USB-C power
    Can you post or link a schematic if on this forum?
    TBTA_LDO_BMC 0V
    The BMC interface is used by the power delivery controller to negotiate the power delivery contracts (voltage and current) using the CCx pins.
    If the LDO is 0v, then no communication can occur.
    Which power delivery controller is onboard this logic board?
    • kuba2102
      • Jan 2020
      • 45
      • Scotland
      That's what sits there tps65982dc attaching schematic and boardview. The thing is the TBTA_LDO_BMC only goes to one capacitor and nowhere else on the net
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
        05-29-2024, 02:01 PM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! ๐Ÿš€
        I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
        Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • LimesKey
        Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
        by LimesKey
        Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
        10-17-2025, 05:33 PM
