Hp 15-cs2023ca USB 2.0 not working
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Re: Hp 15-cs2023ca USB 2.0 not working
    Crystal can be tested with DSO. Should be located near to SOC.
    sir if the crystal ok and frequency showing on oscilloscope (e.g 32 Khz). so, does it mean that all of its circuit ok? or should we use every part?
    • mon2
      • Dec 2019
      • 14691
      The soc that is responsible for the usb state machine uses a 24mhz reference crystal. Locate it with the keyword 'xtal' in the schematic.
      Then measure the operation with an oscilloscope to see if it is oscillating. A defective crystal or a crystal with the wrong frequency will make the usb engine appear faulty.
      If available, replace the part for a quick test. Do not lose the original part(s).
      The scope should measure 24mhz and oscillate with a sine wave.
      There is also a local clock crystal of 32.768khz value. If the clock settings are stable and the clock is accurate, likely this 32.768khz is ok.
      • mon2
        • Dec 2019
        • 14691
        Also confirm the resistors linked to the USB operation with this SOC.
        See attached.
        • mferna14
          • Jun 2018
          • 1046
          mon2 thanks for the info... My dear do you have the schematics for this board or you have just posted generic photos of any random schematics with this SOC???? Kindly info me, troubleshooting will be much easier for me. & I have so many of the 24Mhz crystals, I can just replace it with a new good one.
          • mon2
            • Dec 2019
            • 14691
            It is from the posting made here:
            https://www.badcaps.net/forum/showthread.php?t=102818
            which I am assuming is close to your logic board - perhaps not 100%.
            Either way, it is a crystal so search for a shiny metallic component on your logic board or post pics of this area. It should be either stamped with '24' or silk screened with the same to denote the frequency.
            • mferna14
              • Jun 2018
              • 1046
              Much appreciated mon2., will do so later & will inform you. Thanks
              • mferna14
                • Jun 2018
                • 1046
                mon2, I am expecting this is the correct crystal 24MHz, I will replace it with a brand new one.. Thnaks
                • mon2
                  • Dec 2019
                  • 14691
                  Yes. It only a suggestion since you have lost a block of usb ports.
                  From a distance, the crystal package appears to be 3225 but check with a micrometer. 3.2*2.5 mm ?
                  • mferna14
                    • Jun 2018
                    • 1046
                    Mon2, I got the exact replacement, but it was a knowledgeable try... Did not work at all. Same problem. I think mcplslg123 is right, it's the SOC which is defective & I should not be wasting more time on it. It's not only the USBs, but also the SD card Reader & the camera do not work. I am going for a new motherboard. Thanks for everyone's effort, I appreciate all your help.
                    • emil_t
                      RTX3090 working fine but fans not spinning
                      by emil_t
                      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                      04-12-2024, 06:54 AM
                    • kamiewtype
                      MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                      by kamiewtype
                      I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                      The specs are:
                      MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                      Intel core i9-10900kf
                      2x16gb Corsair Vengeance kit
                      BIOS ver is E7D06IMS.1B0, from 6/12/2023
                      The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                      I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                      11-01-2024, 10:52 AM
                    • Björn Brunkau
                      Palit 980ti no FBVDDQ, no NVVDD, all other voltages working fine
                      by Björn Brunkau
                      Hi there,
                      I am looking for help with my broken 980ti. Had a bad DrMos (the bottom one) and replaced it, card worked for a short moment, but I got another shortes DrMos (second one) and replaced that one aswell.
                      Now I don't measure any shorts, I have 12v, PEX, 5v, 3.3v all working fine (probing points on card), but I can't get any voltage at FBVDDQ or NVVDD probing points.
                      Where could I check to find the fault?
                      You think my first DrMos could be bad, because I read that the first one will activate core?
                      Don't want to replace that one when I can just test other...
                      05-11-2024, 10:41 AM
                    • waterchill
                      Apple iPad Pro 12,9" 4Gen no charging, but working fine
                      by waterchill
                      Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
                      So I started to replace this parts:
                      - replaced usb-c port -> no result
                      - replaced battery -> no result
                      - replaced usb-c chip CD3217B12A -> no result
                      - replaced 343S00326 -> no result
                      - replaced 343S00327 -> no result
                      - replaced 343S00328 -> no result
                      I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
                      04-30-2024, 05:37 AM
                    • wshadow
                      HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                      by wshadow
                      I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                      One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                      The defective board contains a Win10Pro license in BIOS.
                      The other board is working perfectly fine, but only includes a FreeDOS "license".
                      I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                      09-15-2025, 09:04 AM
