A2159 Touch Bar sensor is not working.
  • r1kku
    • Jun 2024
    Hello, I have an MacBook Pro 2019 A2159 but the Touch Bar touchscreen is not working.
    I disassembled the laptop and I saw that L5100 is burned, I removed it and I connected that rail and it seems to be working. It's a problem if I leave it like this? Or I need to install a new inductor?
  • obelix24
    Macbook Air 2020 (a2179) - touch id not working
    by obelix24
    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
    02-09-2025, 12:57 PM
  • alpersen
    Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
    by alpersen
    On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
    10-24-2025, 01:55 AM
  • Gabriel Lucas
    microsoft surface pro 5 touch screen not working
    by Gabriel Lucas
    Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
    02-18-2025, 09:24 AM
  • ahmarzo
    MacBook Air a 1466 keyboard and touch not working
    by ahmarzo
    Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
    The voltage on connector j4800 is following
    Pin no 1-3.3v
    Pin no 10 3.3v
    Pin no 14 - 5v
    Pin no 15-20 all pins have 3.3v
    Have reballed the ic u 5000. And tried another ssd with working os .
    10-18-2025, 10:40 AM
  • monkeigh
    Macbook a2159 Hall sensor not working correctly
    by monkeigh
    Hi All,
    New user here found this website because I am having some trouble fixing my macbook A2159.
    My wife accidentally pushed over a vase filled with water and just a tiny but splashed into my macbook..
    I opened it up and removed the motherboard to clean it with IPA. when it was dry i put it back together and it worked again. But when I close the lid it goes into sleep and it wont turn on the screen when I open the lid.
    The computer is running and working but only on an external monitor. I have to reset the computer to have it work...
    02-12-2022, 08:41 AM
