A1989 (820-00850) - 5V@0.23A - shorted usbc cable
  • wnt2fx
    • May 2021
    • 25
    dear fellow tech enthusiasts, I would appreciate your help ! I have an 820-00850 here that died on a squeezed/shorted charging cable.
    I found several shorted ldo's on both U3100 and U3200. I replaced them with cd3215c00 ( originally c00Z )
    D3301 was shorted, removed without replacement for now. No other visual / obvious findings. ports look good.
    4,86V / 0,23A on usbc meter and ppbus 12.28V, ppdcin_g3h 5V and pp3v3_g3h 3.3V - all ports/orientation. Nothing obvious on a thermal picture, only t2 warms up to 35Celsius.
    1V1 LDO missing on u31/32 ! all other LDOs present on all ACEs.
    PP3V3_UPC_XB LDO and _TA LDO are present at U2890 / UB090
    (Only when charger connected to the corresponding port/orientation (just one at a time)):
    pp1v1_upc_xa_ldo_bmc - 0V
    pp1v1_upc_xb_ldo_bmc - 0V
    pp1v1_upc_ta_ldo_bmc - 1.1V
    pp1v1_upc_tb_ldo_bmc - 1.1V
    usb CC around 1.75V ( of which each time 6(7) do oscilate)
    few diode mode readings:
    pp1v1 ldo'S - all four around 0.47
    pp20v_usbc_xa_vbus - 0.17
    pp20v_usbc_xb_vbus - 0.13
    pp20v_usbc_ta_vbus - 0.17
    pp20v_usbc_tb_vbus - 0.13
    this seems not ok to me. Am wondering if I should remove other diodes on pp20V lines, doubt the new or even the 2 left original cd3215 or if I should think about the tbt rom next. I am unsure what steps to take best next.
  • mon2
    • 14169
    Re: A1989 (820-00850) - 5V@0.23A - shorted usbc cable
    U31/U32 are suspects. You must have the 1v1 ldo rail for the bmc communication to function to allow for the negotiations of the power delivery contracts.
    The current draw is too high for the logic board in this state. The 5v default power rail is being pulled down from an excessive load.
    Are these cd3215 devices from a donor board or purchased from a vendor? Properly reflowed and did the hot air 'dance' ?
    The market does show parts available with c00 and c00z suffix. If you continue to have issues, source the c00z.
    With no power, check the resistance to ground of each pp20v rail and the CCx (communication) line to compare. This may show us where there are damaged esd diodes.
    • piernov
      • Jan 2016
      • 4435
      • France
      Normal on T2 boards.
      • mon2
        • 14169
        More ...
        https://boards.rossmanngroup.com/thr...battery.59438/
        • wnt2fx
          • May 2021
          • 25
          hey guys, thanks for helping out !
          my soldering should be fine. due to often too low air flow for a real dance I confirm with light taps on the side if all is melted well, if the chip snaps right back.
          Regarding wether to trust the source of the two cd32c00 I used or not is difficult to say. On the one hand the shop does not seem to have any products online since a while, on the other the general given feedback is ok. the precise feedback for that product is not available. https://www.aliexpress.com/store/3177036 Bought in october 21. One piece 6,25€. Same order cd3217b12 18€. Generally I look for good product feedback before buying.
          So I can not be sure and should source few trusty cd3215c00z / donor boards clearly anyways. Will do so tomorrow. But as I can not yet be sure either that the ACEs are the problem I would like to look better into other possible reasons ( like diodes, cc lines, rom(s), maybe "scanning" for shot resistors / lines)
          Thanks for your link mon2. I read that as well as https://www.badcaps.net/forum/showth...=104877&page=2 before. Confusing and of hints to follow, as well as https://logi.wiki/index.php/CD3215_Bootup_Sequence. Went over it again. Have to sort my thoughts. Will post CC lines resistance values later when I am back at the board. I find theese readings shady enough for the time beeing
          2nd and 3rd values taken with highest manual kohm setting.
          diode mode red GND / resistance red GND / resistance black GND
          pp20v_usbc_xa_vbus - 0.17 / 12k / 50k ( 3rd value in auto mode: continuously jumping, high values to 0L )
          pp20v_usbc_xb_vbus - 0.13 / 5k / 30k (dont remember auto mode readings but they had been constant)
          pp20v_usbc_ta_vbus - 0.17 / 12k / 400k ( 3rd value in auto mode: continuously jumping, high values to 0L )
          pp20v_usbc_tb_vbus - 0.13 / 5k / 30k (dont remember auto mode readings but they had been constant)
          • wnt2fx
            • May 2021
            • 25
            mixed something up so here pp20v_usbc_??_vbus resistances correction:
            Only took traditional resistance now. Will maybe check later if I maybe made a mistake as well noting down Rs red GND.
            -manual- because auto mode was oscilating/fluctuating
            xa 50k
            xb 30k constant "slow" falling -manual-
            ta 380k -rarely it seems above 400 and then needs manual mode too for stated reason
            tb 25k constant "slow" falling -manual-
            CC Pins:
            xacc1 xacc2 xbcc1 xbcc2 tacc1 tacc2 tbcc1 0L but USBC_TB_CC2 - 0.86M
            Rs in circuit:
            RB640 - 0.538k
            RB630 - 0.481k
            RB660 - 0.498k
            RB650 - 0.577k
            R3460 - 0.509k
            R4350 - 0.529k
            R3440 - 0.543k
            R3430 - 0.499k
            • Simplebeans
              • Sep 2021
              • 134
              Hi wnt2fx can you post all the voltage readings for the 4 LDO rails on all four of the CD3215's, So that's the U3100, U3200, UB300 and UB400. If you need any help with what signals you need to measure for this let me know.
              And are you using a Genuine Apple 61W USB-C Power Adapter with the USB-C Charge Cable?
              • wnt2fx
                • May 2021
                • 25
                Hello dear helping people ! Sorry for never replying, I was damn out of order the last months. The problem is yet unsolved, did not spend a single second since back then. Will definetely get my head into this again bur rather in February because I have more urging things right now. Some of them electronics too so I will post for seeking help regarding other subjects before I continue in this one. I will check again with original 90+ apple charger, which I did not have back then. 4x4 LDOs to measure to be done. You mean each time plugged in another port ?
                best regards
                • Simplebeans
                  • Sep 2021
                  • 134
                  best regards
                  Yes and whenever you are ready let me know and ill be glad to help.
                  • reessi
                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                    by reessi
                    Hello:
                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                    I started on the ACER:
                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                    10-29-2024, 11:31 AM
                  • Yanleb
                    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                    by Yanleb
                    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                    D608, good
                    D618 RF101L4S, good (See warning 1 below)
                    D619 RF101L4S, good (See warning 1 below)
                    D865 RF101L4S, shorted (See warning 1 below)
                    IC464 Inverter HA MC74HC1G14, shorted...
                    03-09-2020, 12:00 AM
                  • modtool
                    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                    by modtool
                    Hi to all,
                    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                    04-01-2025, 08:22 AM
                  • BalkanBoy
                    Dead Razer Blade 14 2022, shorted CPU?
                    by BalkanBoy
                    today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                    Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                    I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                    Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                    I removed coil and injected 0.7V, it draw around...
                    09-27-2024, 12:44 PM
                  • barry101
                    Apple 820-3662 VCore shorted to ground.
                    by barry101
                    Hi, Would appreciate some help.
                    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                    Get charger light but no fan spin or chime. No liquid damage.
                    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                    06-24-2025, 07:34 AM
