Lenovo NM-C121 board,Help remove shorting from burnt pad
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Hello friends,
    I keep coming back for help and this community has never disappointed me. So I have this Lenovo NM-C121 board which has no display on screen. Works fine on external display though. Found one of the fuse (F3301) is burnt that supplies the power to the screen. (20 V)
    After cleaning the area I can the damage already done. The area between the pads is burnt. What bothers me that it still shows short on the edp connector side even though there is not a single component on this side ( LVDS cable is not connected )
    How can remove the short to ground when there is no component? The fuse directly connects to the edp connector. Any solutions
    PS : Pics and schematic attached
  • mon2
    • Dec 2019
    • 14023
    Re: Lenovo NM-C121 board,Help remove shorting from burnt pad
    Use IPA (alcohol) and q-tip (cotton swab) to remove the brown flux. Then take a clear picture and post it of the same area again.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Thanks for the reply . Thats not brown flux but layer underneath. The top blue layer is gone.
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Is it internally short and no fix for this ?
        • mon2
          • Dec 2019
          • 14023
          What pins exactly on the EDP connector are showing as a short ?
          How are you measuring this short condition ? Remove all power -> meter in resistance mode -> then short your meter probes to confirm the 'zero' resistance reading by your meter.
          Then use on the EDP connector and post the pins so we can compare against the schematics.
          • IamPritesh
            • Aug 2017
            • 356
            • India
            Meter in beep mode . Red probe to ground and black probe on edp connector PIN 1. Meter beeps and shows a reading of 002.X The fuse is already removed . Please advise
            • mon2
              • Dec 2019
              • 14023
              Remove all power. Meter in resistance mode.
              Measure the resistance to ground of the same pins on the eDP connector. Polarity of the meter probes does not matter.
              If the meter shows '1' or 'OL' then switch to the next higher meter scale.
              Post the readings.
              • IamPritesh
                • Aug 2017
                • 356
                • India
                Post the readings.
                Will do that as soon as I m at my bench.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  The edp socket is not burnt internally??
                  • IamPritesh
                    • Aug 2017
                    • 356
                    • India
                    Post the readings.
                    Meter reading in resitance mode - 002.5
                    No damage is visible to edp socket . Please refer to the attached image.
                    • mon2
                      • Dec 2019
                      • 14023
                      So the resistance measurement is 2R5 = 2.5 ohms to ground?
                      What may be happening here is that the top pcb layer has been burnt away and the exposed layer is now layer #2 of this multilayer pcb. Often in the pcb layer stack up, the next layer (#2) will be the ground layer.
                      One of the fuse pcb pads may be touching the now exposed ground plane.
                      Continue in resistance mode on your meter and do the following:
                      1) short the meter probes. What is the resistance?
                      2) place one meter probe in the brown area of the pcb where the fuse was burnt. Other meter probe to ground on the logic board (metal shield or similar). What is the resistance?
                      3) test again with probe on metal shield and other on the fuse pad on the pcb. Resistance reading? Repeat with the other fuse pad. Resistance reading?
                      4) schematic shows 2 * capacitors on the same edp connector pins. Do you have these on your logic board? If yes, remove each capacitor and test again to see if the resistance changes.
                      • IamPritesh
                        • Aug 2017
                        • 356
                        • India
                        There are no capacitor on those lines. There are no installed on the board. Strange issue ..how to solve this. Can I cut that part of the board layer
                          • 20707
                          You`ve only replied to 4) what about 1) , 2) , 3)
                          • IamPritesh
                            • Aug 2017
                            • 356
                            • India
                            Sorry here they are:
                            1 resistance reading when both probes are connected to each other : is 0000
                            2 resistance of the brown area where the fuse was burnt
                            : 2.4K
                            3 resistance at other fuse pad : 6.5K
                            New Images attached
                            • IamPritesh
                              • Aug 2017
                              • 356
                              • India
                              Anyone ever encountered this kind of strange issue ?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                There is nothing strange in this issue. Its Ground layer exposed to pad of burnt fuse. Scrap with a sharp pointed knife unless the resistance is OL.
                                • Popel1083
                                  Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                                  by Popel1083
                                  I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                                  SN: QB08570065
                                  MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                                  08-06-2024, 05:52 PM
                                • xsd611
                                  Lenovo X270 Bios - remove Whitelist
                                  by xsd611
                                  ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
                                  07-13-2025, 09:13 PM
                                • anton brunner
                                  Lenovo Ideapad Duet 3 (11IAN8) - Remove Password
                                  by anton brunner
                                  Hello Everyone,
                                  after some struggle I managed to sucessfully dump the Bios of an Lenovo Ideapad Duet 3 (11IAN8). Can someone help me remove the Bios Password?
                                  MO: YM90B49150N2
                                  MTM: 82XKS00500
                                  S/N: YM10CPP2
                                  Thanks in Advance, the Bios dump is attached....
                                  05-23-2025, 04:56 AM
                                • omenwolf
                                  remove my bios password lenovo yoga 7-14ARP8
                                  by omenwolf
                                  remove my bios password lenovo yoga 7 14ARP8 motherboard NB6380C_MB_V3 s\n: YX096SWC...
                                  11-14-2024, 08:37 AM
                                • fontanero1620
                                  Lenovo IdeaPad g40-30 password remove
                                  by fontanero1620
                                  Hello, I need remove the password to access the BIOS configuration. I already tried the auto patcher and it doesn't work for my laptop.
                                  My laptop info:
                                  Model: Lenovo g40-30 type 80fy
                                  Motherboard: ACLU9/ACLU0 nm-a311 rev 1.0
                                  Bios type: insydeh20...
                                  11-13-2024, 08:32 PM
