Dell n5010 uma transaction done, there is a problem
  • kaan51
    • Dec 2020
    • t
    Hello my dear friends
    I'm sorry for my bad english
    Dell n5010 uma done but won't boot after dell logo
    There is an image and it enters the bios, but the usb and hdd do not boot, it stays on the black screen
    This is the first time I've encountered a problem like this.
    Thanks in advance for your help, best wishes
    Mainboard:09909-1 DG15 MB 48 . 4HH01. 011
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: Dell n5010 uma transaction done, there is a problem
    don't you try to flash bios?
    I was able to fix this kind of issue on HP 430 g4 laptop by flashing bios.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Remove R3715. Located near EC bios chip. Bright chance this will solve your problem.
      • toti24
        (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
        by toti24
        dell precision m4600 laptop
        i7 2760qm
        8gb ram 750gb HDD
        intel hd 3000 integraded and nvidia quadro 2000m
        pleasea bear with me english isnt my language and ill try to be as clear as possible
        note i live in mexico in a very small town..
        thank you.
        laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
        the brick happened when i was installing win 10 using usb.
        used rufus and officia microsoft.iso
        it finished copying files from usb...
        03-06-2022, 08:39 PM
      • SDNarcia
        Dell 15R-5521 keyboard problem (KBC?)
        by SDNarcia
        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
        As additional information,...
        07-20-2024, 10:47 PM
      • Achille15
        Dell N5110 problem
        by Achille15
        so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
        03-29-2025, 04:41 PM
      • minaedward
        Dell N5010 keyboard
        by minaedward
        Hi all
        I have a dell n5010 that shows black screen after the dell logo and freezes
        But when I remove the keyboard it works fine and boot the windows
        The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
        But after the dell logo it causes the laptop to freeze
        Any ideas why ?
        09-29-2024, 05:24 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
