Dell e5420 power on then off
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Dell e5420
    (KRUG 14" UMA Rev. A02 10ELT16G001-A, of FOXCONN) no exact schematic could be found
    Power on, then off after a few seconds (even without ram and processor same situation)
    Takes till 1.40A on dc supply
    Core ok
    Pltrst ok
    DRAMRST ok
    Any guidance please
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell e5420 power on then off
    Look for corrosion under microscope. Bios flashed??
    • usyusy
      • Sep 2021
      • 171
      • Pakistan
      ok sir, bios has not flashed as i don't have it, will do a request in the bios section.
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        Sir a bios was flashed, but takes dc supply only 0.14A,
        No core now
        Even again reflashed from backup bios, but still same. What could be its science.
        Some dust was cleaned also, no noticeable corrusion was found.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          1.8V rail is present??
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            Yes sir a small coil showing one side about 2.97v and other side 1.79v, when powered on
            • PantherDave
              by PantherDave
              Hi all!
              I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
              05-29-2024, 02:01 PM
            • Mark01
              Dell Optiplex 7490 AIO - red power led after flash
              by Mark01
              Hi guys,
              This is my first post! ๐Ÿš€
              I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
              Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
              07-04-2025, 12:54 PM
            • zlr8r
              Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
              by zlr8r
              hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
              Ill try and give as much info as I can.
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              When I received this , it would only flicker on the KB backlight for a second, then off and on.
              Then it started getting weirder!
              Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
              12-12-2023, 09:31 PM
            • LimesKey
              Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
              by LimesKey
              Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
              10-17-2025, 05:33 PM
