Hello i have a weird problem on an Acer 5742G. The laptop start and work perfectly on battery. But on ac adapter only i can't power it on. I have make a lot of test and check but i can found the problem. But at the beginning i have found corrosion on and around the PU18. I have clean the area but same problem. I have replace some cap that have not the good resistance and also replace the pu 18 and PD1 but same problem. If i check the PL27 and PL28 on battery i have fixed voltage 3 and 5v (always volatge) but on ac adapter the voltage run from 2 to 3v and 3 to 5v constantly. Because i have an other board like this i have replace the 3v/5v chip PU16 because when i plug the adapter it's seems there is an shortcut, same with PQ46 and also it have a ugly face. I have try to replace the 2 first mosfet PQ51 and PQ52 because i have 19v on first, 18.85v betwen and on the gate of PQ51 and after pq52 i have voltage that oscilate between 7 and 9v. For now i have no idee what i can check. Could you please help me ?
					Acer 5742G Power only on battery.
 Re: Acer 5742G Power only on battery.
 Thanks For the info. Is there a section i have to read for my problem ?Comment
 Review the operation of your 2 x DCin mosfets.
 These are P-channel mosfets so the gate voltage needs to be more negative / lower than the voltage they are passing.
 The gate voltage appears to be ok but is not working properly for PQ52.
 Remove all power -> check the resistance to ground for PQ52, pin 5-6-7-8 (pick any one to test); meter on one pin and other meter to ground.
 What is the resistance ? If the resistance is not too low, the load on the logic board is ok and the ~19v should travel through.
 With no power -> meter in resistance mode -> check the resistance of each mosfet as follows:
 source (1-2-3) & drain (5-6-7-8)
 source (1-2-3) & gate (4)
 gate (4) & drain (5-6-7-8)
 post each measurement and the scale used on your meter for these tests. If the resistance is low, the mosfet is defective and must be replaced.Comment
 Hello thanks for the answer, here is the value.
 PQ52 drain to ground = 2.24M (meter on 200M) but if il let the meter apply the value decrease a little
 PQ52
 source (1-2-3) & drain (5-6-7-8) red to black give 2.20M (meter on 200M)
 source (1-2-3) & gate (4) red to black give 2.43M (meter on 200M)
 gate (4) & drain (5-6-7-8) red to black give 0.20M (meter on 200M)
 PQ51
 source (1-2-3) & drain (5-6-7-8) black to red give 1.28M (meter on 200m)
 source (1-2-3) & gate (4) black to red give 0.20M (meter on 200m)
 gate (4) & drain (5-6-7-8) black to red give 1.68M (meter on 200m)Comment
 Here is more info, the voltage of PU18 ( i have replace it but same )
 1 0.117v
 2 3.248v
 3 0.910v
 4 0.000v
 5 3.7 to 4.6 oscilating
 6 3.240v
 7 3.5 to 4.9v oscilating
 8 18.652v
 i think the oscilating voltage is the problem and if i check resistance of components near (like PR389) just after unplug the power the resistance is very high and take many time to decrease to normal value. Is this normal (for info this is the zone of liquid damage)?Comment
 Remove all power -> meter in resistance mode.
 Confirm the resistance from the current limit resistor @ PR351 to pin 19 of PU17. What is the resistance ?
 Confirm the resistance from the current limit resistor @ PR351 to pin 20 of PU17. What is the resistance ?
 From the schematics, the resistance of each leg must be ~20 ohms else the charger IC will believe something is wrong and will shut down the mosfets.
 Although the same gate voltage is driving also the PQ51 mosfet - does it not oscillate like PQ52 ? Do confirm that the mosfets are soldered in properly.
 We recently wasted too much time in repairing an iMAC 5K (another shop gave up on it) -> we found the bad boy shorted cap but did not solder back the removed dual mosfet correctly. While checking with our needle like probes, the component moved !! The PCBs are multilayer and can sink temps quickly so be sure to apply ample flux and heat. Full details of the iMAC repair to follow soon.
 Review the voltages on charger IC @ PU17. Post the measurements of each pin - proceed with extra caution so that the pins are not shorted.
 The mosfets look to be ok.Comment
 Thanks again, here is the mesure you asked me :
 @PR351 to pin 19 of PU17 is 2.30 ohms (meter on 200 ohms)
 @PR351 to pin 20 of PU17 is 20.04 ohms (meter on 200 ohms)
 PU17
 1 0.006v
 2 0.083v
 3 0.001v
 4 0.006v
 5 0.071v
 6 0.017v
 7 0.150v
 8 0.001v
 9 0.001v
 10 0.001v
 11 0.001v
 12 0.001v
 13 0.001v
 14 0.114v
 15 0.006v
 16 7.4 to 9.7v oscillating
 17 7.4 to 9.7v oscillating
 18 7.8 to 10.0v oscillating
 19 7.6 to 10.0 oscillating
 20 7.6 to 10.0 oscillating
 21 7.5 to 9.7 oscillating
 22 7.6 to 9.4 oscillating
 23 0.284v
 24 0.001v
 I send you the PQ51 and 52 voltage right after diner.Last edited by SMDFlea; 09-05-2022, 01:43 PM.Comment
 So,24 0.001v
 1) PU17 charger IC is not being powered (pin 24).
 2) See attached. For PU17 to be powered:
 a) see attached datasheet for this IC.
 b) power to this ic is only if mosfet PQ54 is on
 c) PQ54 will be on only if the gate is a negative (lower) voltage that it is passing
 d) gate will be lower only if PQ55 is on
 e) PQ55 will be on only if gate is a high voltage
 f) gate will be a high voltage only if one of the diodes inside PD10 is conducting
 g) PD10 is linked to the GPIO pins of U32 (KB926QFD3_LQFP128_14X14)
 If U32 is flash based - consider to reflash it.
 Review the voltages of the above trail. Post your measurements.Comment
 Thanks again. So there is mesurment of pq54, PQ55, PD10. I'm afraid that there is always this volatge oscilating. I see another post in this forum where the guy have quite the same problem of me and the oscilating votage is gone after a capacitor replacement near PU18, like you say my PU18 have water damage too so possibly same problem ? I have no the programer for the U32 but i have another board with same component but la-5893p instead od la-5891p ( both board is 5742 )So,
 PQ54
 1 0.001v ( many time when i just plug the probe i get 0,2v to0.6v but in 2-3 seconds it drop to 0.001v )
 2 7.6v to 10.00v oscilating
 3 7.6v to 10.00v oscilating
 PQ55
 1 7.5 to 9.8v oscilatingv
 2 0.006v
 3 0.001v
 PD10
 1 0.004v
 2 0.002v
 3 0.003v
 And also the voltage of PQ51 and PQ52
 Voltage
 PQ51
 5-6-7-8 = 19.332v
 1-2-3 = 18.842v
 4 = 18.838v
 PQ52
 1-2-3 = 18.842
 4 = 18.838v
 5-6-7-8 = 7.6 to 9.9v (with the charged battery plug i have fixed 11.386v and i can power on the laptop)
 I think the problem is from oscilating voltage but why ???Comment
 Another info, i have check with a thermal cam and found a part of the board a little more hot ( on the other board i have not this case ) And this part is right underneath the part with PU18 that have water damage so it could be the reason of oscilating voltage. But i doesn't found shortcut on this 2 area.Comment
 So now because of my last message, i decide to made the replacement of
 PR301
 PR298
 PR297
 Now i have on
 PU18
 1 3.178v
 2 3.247v
 3 3.684v
 4 0.001v
 5 2.251v
 6 3.240v
 7 0.025v (not normal this time i think)
 8 18.677v
 and
 Voltage
 PQ51
 5-6-7-8 = 19.340v
 1-2-3 = 18.852v
 4 = 18.848v
 PQ52
 1-2-3 = 18.852
 4 = 18.848v
 5-6-7-8 = 18.542v
 It's seems good this time
 But not resolve and new symptoms
 So the laptop boot already if battery present but not if i plug the adapter. If i just plug the battery i can power on the laptop and if i plug the adapter after the laptop stay on and the battery charging led appear. At this moment if i unplug the battery the laptop stay on.Comment
 So yes i can unplug the battery ( step is to plug the battery, power on the laptop, plug the adapter then light of charging appear, then unplug battery and the laptop continue working.
 And there is the voltage, this time it's good but i can let the laptop like this.
 Voltage
 PQ51
 5-6-7-8 = 19.035v
 1-2-3 = 19.025v
 4 = 8.081v
 PQ52
 1-2-3 = 19.025
 4 = 8.081v
 5-6-7-8 = 19.013vComment
 Oh and for info if i plug both the battery and the adapter , i can't power on the laptop this time. Previously before replacing the capacitor i can start with both battery and adapter but remember i have voltage after PQ52 that oscilate between 7 and 9v +-.Comment
 Yes it work fine but i have to start the laptop with only the battery before, then plug the adapter and after that unplug the battery.
 And like i say just the message before, if i plug the battery and the cable i can't start the laptop, i have to start with only the battery or it's not power on
 So i can't let the laptop in that state.Last edited by eukal; 09-04-2022, 05:30 PM.Comment
 With only the power adapter, measure the voltages on each pin of pu17. The gate voltage is correct when the adapter only is used. We need to confirm the other voltages are as well.
 After the above measurements, remove all power. Meter in resistance mode. Check the resistance of the mosfet pins, like before, for the high and low side battery charger mosfets. Post the readings.Comment
 Here is the voltage, i want to tell one more time i can get the good gate voltage only if i start the laptop whit the method i tell you so first plug the battery, then start the laptop, then plug adapter, then remove battery. If i just plug the adapter whitout this procedure i have gate voltage at 18.8v and the laptop no start and no charging led.
 So
 laptop start ( battery plug, power on, plug adapter, unplug battery )
 0.399v
 0.173v
 0.000v
 0.009v
 0.002v
 0.002v
 0.003v
 0.000v
 0.000v
 0.000v
 0.000v
 0.000v
 0.000v
 0.248v
 0.369v
 0.564v
 0.835v
 0.783v
 19.018v
 18.990v
 0.760v
 0.772v
 0.761v
 1.4 to 1.7v oscillating
 laptop not started and just adapter plug
 0.002v
 0.042v
 0.001v
 0.002v
 0.089v
 0.044v
 0.003v
 0.000v
 0.000v
 0.000v
 0.000v
 0.000v
 0.000v
 0.117v
 0.001v
 0.010v
 0.454v
 18.665
 18.663v
 0.100v
 0.098v
 0.748v
 0.004v
 I check the résistance nowComment
 Excuse me but where are the highside and low side battery charger mosfet ?With only the power adapter, measure the voltages on each pin of pu17. The gate voltage is correct when the adapter only is used. We need to confirm the other voltages are as well.
 ThanksComment
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by DenKDear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down...
			This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
			by ahmarzoI have acer laptop tmx314-51 with part no 6050A3020501.
 The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
 But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
 I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
 The schematic is not available...
			by mkdjHello everyone,
 Mark and model: ASUS X571
 Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
 Tests already made:
 - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
 - I have removed...
- Loading...
