Acer 5742G Power only on battery.
  • mon2
    • 14672
    Re: Acer 5742G Power only on battery.
    where are the highside and low side battery charger mosfet
    PQ62 = high side battery charge mosfet
    PQ64 = low side battery charge mosfet
    These 2 mosfets essentially turn ON / OFF to dial up the desired voltage for the battery to charge. The charger IC closely monitors this voltage and the current consumed by the battery pack during the charge cycles to keep the process safe as to not start a fire, etc.
    Are you using an official power adapter for this logic board or a lab adjustable power supply ?
    Confirm the voltage of +RTCBATT.
    • eukal
      • Jul 2012
      • 43
      • belgique
      Thanks again.
      Here is the reading
      Range in 200M
      PQ62
      1-2-3 = go from 0.42m to 0.90m and continue to up by 0.01m each 5-10 seconds
      4 = oscilating 1.41m to 22m
      5-6-7-8 = 2.66M
      PQ64
      1-2-3 = 00.01k this in range 2k
      4 = go from 6M to out of range
      5-6-7-8 = go from 0.42m to 0.90m and continue to up by 0.01m each 5-10 seconds
      And i use an universal adapter but i can use an original acer adapter if needed.
      For the +RTCBATT . Whitout adapter i have 0.120v ( for info the original rtc was desolder because no more voltage in it and i have buy another one, i wait it to arrived by post) And 3.108v with adapter plugged
      • eukal
        • Jul 2012
        • 43
        • belgique
        Is the cmos battery required ?
        • eukal
          • Jul 2012
          • 43
          • belgique
          I have continue to check why the laptop can boot with battery but no with adapter plug in and not with only adapter. So with only battery the gate of pq51 and PQ52 is at 12v so the 19v go to pq52 out whitout problem. If i plug the adapter or with the adapter only the gate saty a 18.84v so no 19v after pq52 but 18.52v.
          I manage to check one more time PU18 because it was the part with water damage and i think i have found one problem. So the pin 5 have 4.8v (around 4.3v is awaited on this pin i have seen on other post) with the battery but soon i pluf the adapter the voltage drop to 2.4v and the laptop refuse to power on. I have 2.4v too with only the adapter. I have try to put 4.3v with my adaptable power supply and only the adapter no battery and wow the laptop power on whitout problem so now i'm sure the problem is here but i doesn't understand why. Have you ab idea ? Thanks
          • eukal
            • Jul 2012
            • 43
            • belgique
            Continue checking, i have not the +5alw on pin 2 of PQ71 and if i plug 5v on it with adaptable power supply i can start the laptop.
            • eukal
              • Jul 2012
              • 43
              • belgique
              #26
              SO i stop now to check because i think i have found the problem, there is a pad that are scrap on 3v/5v chip and i can't repair it, i have try with a tiny wire but no luck the chip become hot, i have try to swap the chip Rt8206b with TPS51427 i have on the other board ( it's the same) but same so i think there is another problem and now the laptop doesn't want to power on including with only the battery. Better luck next time. I hope this post can help another one. Thanks for your help mon2.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • DenK
                Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                by DenK
                Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                12-06-2024, 01:29 AM
              • survivalbloke
                Acer Predator Helios 300 - will not power up if battery is CONNECTED
                by survivalbloke
                This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                06-25-2025, 12:20 PM
              • ahmarzo
                Acer TMX314-51 laptop battery problem
                by ahmarzo
                I have acer laptop tmx314-51 with part no 6050A3020501.
                The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                The schematic is not available...
                04-11-2025, 09:14 AM
              • mkdj
                by mkdj
                Mark and model: ASUS X571
                Tests already made:
                - I have removed...
                07-14-2025, 09:16 AM
