Dell XPS, Keyboard Glitching
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    MODEL NAME AZ10
    PCB NO :LA-F211P
    After bumped battery removal the keyboard doesn’t work properly. When pressing any key, it will react 5-7 times after 5-15 seconds.
    The keyboard connected to KBC board. The cables are fine, all signals are checked
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    Re: Dell XPS, Keyboard Glitching
    Originally posted by EdwardGeo
    MODEL NAME AZ10
    PCB NO :LA-F211P
    After bumped battery removal the keyboard doesn't work properly. When pressing any key, it will react 5-7 times after 5-15 seconds.
    Dell XPS 15-9575 2-in-1
    Schematic: https://www.badcaps.net/forum/showthread.php?t=106363
    The problem comes from kbc board. That board is connected to EC through I2C interface. Will analyse data packages. My theory is based on EC as master sends command to read KBC ECE1117 buffer, but the buffer is empty or stuck with keycode.
    In different laptops I have saw the internal iospace ram buffer with keycode, and keycode always remain the last status. So if ECE1117 has a failure, then it will not fill a buffer, it will not reset a buffer
    • mon2
      • Dec 2019
      • 14679
      Confirm the I2C pull ups are still present on this leg of the circuit.
      Review the 32.768khz clock source on the KBC.
      • EdwardGeo
        • Mar 2020
        • 109
        • Ukraine
        Thanks!
        I2C data and clock present. Have captured traffic, will analyze for difference between keypress “1” and key “2”
        KBC_Det is gnd connected
        KBC_Int is pull up 3.3v, but goes to 0v when key pressed
        • mon2
          • Dec 2019
          • 14679
          Try a bios update
          https://www.dell.com/support/kbdoc/e...aracter-repeat
          • EdwardGeo
            • Mar 2020
            • 109
            • Ukraine
            Incredible! It works!
            Thank you for your help!
            • NotEnough
              Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
              by NotEnough
              I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
              What I've Tried So Far:
              • Reseated the cables.
              • Reinstalled AWCC and AlienFX services.
              • Attempted BIOS downgrade but no improvement.
              • Inspected ribbon cables for damage.
              • Explored the possibility of BIOS or
              10-19-2024, 01:34 AM
            • HTR-Informatique
              by HTR-Informatique
              02-09-2025, 06:51 AM
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • ronaldopdias
              Dell Alienware x17 R1 - Keyboard not working
              by ronaldopdias
              Symptoms:
              No keys work apart from F1, F7, F12 function keys such as keyboard brightness, touchpad enable/disable.
              Keyboard RGB works okay and might be adjustable.
              VERY occasionally it may function but most of the time it is dead.
              The fault is down to the USB data lines not going low when the bus is idle. The keyboard connects over USB, so the issue on the USB data bus causes it to stop functioning.
              The fix is to fit a 1K resistor to the daughterboard that the keyboard + trackpad connect to. The daughterboard is located beneath the battery. The resistor...
              05-13-2025, 04:50 AM
            • SDNarcia
              Dell 15R-5521 keyboard problem (KBC?)
              by SDNarcia
              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
              As additional information,...
              07-20-2024, 10:47 PM
