Asus pro p2440uq rev 2.0 not charging
  • koby058
    • Jan 2017
    • 382
    • israel
    Hi
    i have this Laptop, it was shorted to gnd and not turning on. i have found a shorted cap, removed it now laptop starting but it does not always charging. sometime it will charge the battery. so if started with battery and charger it will take power from the battery.
    but if started on charger only it works ok
    charger IC is Bq24780s . i have replaced it and have same issue
    Can someone help ?
  • mon2
    • Dec 2019
    • 14244
    Re: Asus pro p2440uq rev 2.0 not charging
    Post all voltages on the charger IC.
    • Sephir0th
      • Oct 2020
      • 1282
      I highly recommend to check the diode(s) at charging controller VCC
      FairRepair on YouTube
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Usually when 19V rail is shorted, first dc-in mosfet also gets shorted(though partially). So its worth checking the resistance of both dc-in fets.
        • koby058
          • Jan 2017
          • 382
          • israel
          I have mesured resistence on two first mosfet and the first one was shorted, thank you all
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Did replacing the 1st dc-in fet solved it or not??
            • koby058
              • Jan 2017
              • 382
              • israel
              Yes It did
