Asus pro p2440uq rev 2.0 not charging
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    i have this Laptop, it was shorted to gnd and not turning on. i have found a shorted cap, removed it now laptop starting but it does not always charging. sometime it will charge the battery. so if started with battery and charger it will take power from the battery.
    but if started on charger only it works ok
    charger IC is Bq24780s . i have replaced it and have same issue
    Can someone help ?
  • mon2
    • 14594
    Re: Asus pro p2440uq rev 2.0 not charging
    Post all voltages on the charger IC.
    • Sephir0th
      • Oct 2020
      • 1283
      I highly recommend to check the diode(s) at charging controller VCC
      FairRepair on YouTube
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Usually when 19V rail is shorted, first dc-in mosfet also gets shorted(though partially). So its worth checking the resistance of both dc-in fets.
        • koby058
          • Jan 2017
          • 387
          • israel
          I have mesured resistence on two first mosfet and the first one was shorted, thank you all
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Did replacing the 1st dc-in fet solved it or not??
            • koby058
              • Jan 2017
              • 387
              • israel
              Yes It did
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • dimis1975
                Macbook A1466 2014 not charging with macsafe 2 charger
                by dimis1975
                I have a macboook air a1466 that stopped charging the battery.
                BAT PINS: with or without ADAPTER IN
                1- GND
                2- GND
                3- GND
                4-0V sense pin
                5-3.42V
                6-3.42V
                7- 8.4V
                8- 8.4V
                9- 8.4V
                AC Adapter plugged in: after a lot of of hours some times start charging
                No BAT Connected- Green to Orange
                AC Adapter plugged in: BAT Connected- no light
                The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                Any ideas what’s wrong please?...
                08-05-2025, 03:43 AM
