Dell E 6520 LA-6562P rev. 2.0
  • keruter
    • Mar 2020
    • 6
    • POLAND
    Hello, I've got Dell E 6520 LA-6562P rev. 2.0 without T156 (lan transformator). Can you help me with replacement this item ? What symbol is it.
    Can i connect this shortly ( or how) to test LAN on Windows ?
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: Dell E 6520 LA-6562P rev. 2.0
    Have you checked Schematics??? See this attachment. It will help.
    • keruter
      • Mar 2020
      • 6
      • POLAND
      Thank, This is correct ?
      1 - 24
      2 - 23
      5 - 20
      6 - 19
      7 - 18
      8 - 17
      11 - 14
      12 - 13
      • mon2
        • Dec 2019
        • 14677
        What is the speed of this ethernet port ?
        LAN transformers are quite common and available on the market.
        But first, need to know the speed.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • gambitxp
          help this mosfet what other mosfet can i replace this 6520 dell inspiron 14 model
          by gambitxp
          help what mosfet can i replace this charging mosfet 6520 the brand of laptop is dell inspiron 14 3000...
          06-29-2025, 06:22 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
