Dell LA-G712P MEC1416-NU
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I have one dell LA-G712P. Problem is not detecting battery. On diagnosis, found CLK line is pulled low to 0.85V. Replaced charger IC but still same. Resistor connected to SIO SDA/SCL pins are 4.7K-so fine/Resistors connected to SDA/SCL battery pin connectors are 100 Ohms-so fine. So i think SIO is defective.Adapter is correctly identified-so PS_ID is fine.
    SIO used on mb is MEC1416-NU but i dont have it. I've MEC1418-NU in stock. Are they replaceable?? I've gone through datasheet and MEC1416 Sram is 160KB while MEC1418 has 192KB as SRAM. There is no other difference.
    Whats your opinion guys??
  • mon2
    • 14832
    Re: Dell LA-G712P MEC1416-NU
    Is the pull up voltage present on the I2C SCL open drain line?
    Check if there are any esd diodes near the battery connector which may be damaged.
    With 100 ohm resistors, they will be to current limit these communication lines and therefore can be removed to isolate the circuit. Then can confirm if the bus master SIO is at fault and unable to clock this I2C line.
    Is this SIO programmable? From some quick past reviews, these devices have an internal 8051 microcontroller. So firmware may be required to become the I2C bus master.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Yes, 3V is available as pullup. SIO is programmable and i've already reprogrammed it. There is no ESD diodes-all are @. I tried removing 100 Ohms resistors as well but result is same. SCLK still pulled low at 0.85V.
      Since no one confirmed about my question, i think i'll wait and order the same SIO MEC1416-NU.
      • anshad
        • Nov 2010
        • 249
        To my knowledge, this SIO doesn't have internal flash but SRAM which will be loaded with EC firmware from main BIOS on startup. Isn't a power cycling enough to reload the EC firmware ?. Am i missing something ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          @anshad, you are right but thats only when the SIO is blank. It wont program itself from main if EC Sram has data. So i just erased it with SVOD and put clean me bios so that it can program itself on 1st boot. Since laptop is giving display, i think nothing wrong with erase.write of SIO.
          PS: Will receive new SIO within a day or two. Will update the forum about result,if any.
          • mon2
            • 14832
            @mcplslg123, before replacing the sio chip, can you check the I2C pins in diode mode?
            Then interested to know the same diode readings of the fresh sio controller.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              New sio soldered.Problem is solved and it is detecting battery now. SCLK is now 3.3V which was earlier pulled low at 0.85V.
              @mon2, i already delivered it to customer, so cant give measurements anymore.
              • usyusy
                • Sep 2021
                • 171
                • Pakistan
                sir, are "EC BIOS" and "Program of a SIO" different things?
                2ndly if replace any IO even from same other board should we program it?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  No need to program if SIO is taken from same motherboard. EC bios and program of Sio is usually same.
                  • jacobk1508
                    • May 2016
                    • 69
                    • Viet Nam
                    I replaced the MEC1418-NU from a board of another model, it worked immediately and I didn't need to do anything else. I think everyone just needs to change 1 MEC with the same code
                    • Microm
                      • Sep 2019
                      • 29
                      • Perú
                      Hello, I have a question. I also have an issue with the MEC1416 in a Dell laptop. In my case, the keyboard is not working, so my question is, if I replace it, do I need to reprogram the MEC? Or is the BIOS sufficient? If it is reprogrammable, how did you perform the procedure? Thanks in advance.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        MEC1416 will program itself frrom main bios. recommended to put a clean me bios after sio replacement and then only connect power.
                        • Microm
                          • Sep 2019
                          • 29
                          • Perú
                          Hello, I just replaced the MEC1416 integrated circuit in the Dell laptop, which was having an issue recognizing the keyboard, and now the laptop doesn't turn on. Its initial power consumption is only 0.016mA and it doesn't power on... I assume it's due to some programming issue. Could you help me with this?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            MEC1416 doesnt need programming manually,so either the SIO you soldered is bad or not soldered properly
                            • Microm
                              • Sep 2019
                              • 29
                              • Perú
                              Hello! I changed the MEC1416 and now it turns on, but it still has the issue of not detecting the keyboard. Any other questions? I already changed the keyboard.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                You have not mentioned the mb markings for your laptop-so nothing can be suggested.
                                • Microm
                                  • Sep 2019
                                  • 29
                                  • Perú
                                  Dell Inspiron P93G Service Tag 6V4T4P2
                                  • mon2
                                    • 14832
                                    No. Requesting the white silk screen markings which may be something like 'LA-****'. Or you can take and post pics of the motherboard.
                                    • Microm
                                      • Sep 2019
                                      • 29
                                      • Perú
                                      bucky/ben solo whl/cnl mb tvmhg 17859 This is the model.
                                      • Microm
                                        • Sep 2019
                                        • 29
                                        • Perú
                                        Hello friend, could you tell me the procedure and pins that you soldered to clean the MEC1416, (TDO, TDI, TMS and TCLK)
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • dell_sadness
                                          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                          by dell_sadness
                                          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                          Have extracted the BIN and want to know how to rebuild a clean BIOS
                                          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                          11-12-2025, 02:54 PM
