Hello i have a panasonic fz-m1d no power on , i don't know if it's bios corrupted , i dont find bios available for try this
					panasonic no power on fz-m1d
Re: panasonic no power on fz-m1d
Review the voltages to ground at each coil which are often large and grey in color.
Each coil is linked to a local power supply but it all starts from your ac adapter at ~19v. Search the adapter connector and review 2x dcin mosfets with 8 pins each. These will be controlled by a local battery charger IC which will probably be from Texas instruments (BQ markings on the top surface).
Confirm and share these details.Comment
Perfect.
1) See attached for the datasheet for this charger IC.
2) Review figure 16 - your logic board should have a very similar design onboard. Often, as per Piernov's sticky article above, Q2 (aka 2nd DCIN mosfet) gets damaged.
Confirm that you have 2 more black (smaller size) mosfets onboard. They will be 8 pins and with 4 pins on each side.
Post pictures so we can be sure.
Very likely, one of these mosfets is defective and needs to be replaced but we can confirm it through resistance checks. With resistance checks, NO POWER to the logic board.
We need to check the resistance between the mosfet pins:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)Attached FilesComment
Assuming...7 Photos -
			by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
			by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
			Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for... - Loading...
