panasonic no power on fz-m1d
  • tikanot
    • Mar 2020
    • 67
    • france
    Hello i have a panasonic fz-m1d no power on , i don't know if it's bios corrupted , i dont find bios available for try this
  • z2168235
    • May 2021
    • 6
    • Singapore
    Re: panasonic no power on fz-m1d
    Maybe short motherboard, which is quite common
    • mon2
      • Dec 2019
      • 14691
      Review the voltages to ground at each coil which are often large and grey in color.
      Each coil is linked to a local power supply but it all starts from your ac adapter at ~19v. Search the adapter connector and review 2x dcin mosfets with 8 pins each. These will be controlled by a local battery charger IC which will probably be from Texas instruments (BQ markings on the top surface).
      Confirm and share these details.
      • tikanot
        • Mar 2020
        • 67
        • france
        yes ok i do test i have 3v3 and 5v ok and at the coil near the dc in i have 0v but it's 16v in this motherboard.
        • tikanot
          • Mar 2020
          • 67
          • france
          i have check again at big coil near dc in its 2.2v not 0v
          • mon2
            • Dec 2019
            • 14691
            Post the requested details of the charger IC.
            • tikanot
              • Mar 2020
              • 67
              • france
              It s near thé dc?
              • mon2
                • Dec 2019
                • 14691
                Yes, often it is. Look for a black square part. On the top side will be laser markings of "BQ" or something like this.
                Take and post clear pictures of the logic board near the power in connector.
                • tikanot
                  • Mar 2020
                  • 67
                  • france
                  It s write bq735
                  • mon2
                    • Dec 2019
                    • 14691
                    Perfect.
                    1) See attached for the datasheet for this charger IC.
                    2) Review figure 16 - your logic board should have a very similar design onboard. Often, as per Piernov's sticky article above, Q2 (aka 2nd DCIN mosfet) gets damaged.
                    Confirm that you have 2 more black (smaller size) mosfets onboard. They will be 8 pins and with 4 pins on each side.
                    Post pictures so we can be sure.
                    Very likely, one of these mosfets is defective and needs to be replaced but we can confirm it through resistance checks. With resistance checks, NO POWER to the logic board.
                    We need to check the resistance between the mosfet pins:
                    source (1-2-3) & drain (5-6-7-8)
                    source (1-2-3) & gate (4)
                    gate (4) & drain (5-6-7-8)
                    • tikanot
                      • Mar 2020
                      • 67
                      • france
                      see picture they are 4 mosfet near bq and near the dc in the rear side. Wich one i have to test why they are 5v and 3v3 with mosfet damaged
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • oldschoolgamer
                        Panasonic TX-50EX700B Won't Power On
                        by oldschoolgamer
                        Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
                        I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for...
                        10-26-2022, 04:15 PM
