la-g881p area 51m no power
  • kjchatman
    • Dec 2012
    • 200
    • united states
    I was fixing this for someone and the laptop originally had a backlight problem and i resolved it. then the person tried to replace the keyboard and must've shorted something because now it shows no signs of life. the backlight issue was pretty easy because the burned mosfet on the graphics card was very noticeable. i can't find any shorted caps anywhere on it. the 16v rail and the 3v and 5v rail are there. I need someone give me clue as to what might be missing or shorted
  • kjchatman
    • Dec 2012
    • 200
    • united states
    Re: la-g881p area 51m no power
    it turned out to be the EC
    • javieromex
      • Apr 2016
      • 76
      • México
      Hello!
      Did you need to program it?
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • abajor
        Asus G634j Rog Strix SCAR Power rail shorted nothing hot on thermal camera.
        by abajor
        I haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
        It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
        The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
        It draws 1.86A injecting directly to ground.
        Is this just the way it is when these ultra...
        03-19-2025, 03:23 AM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • guizmo1967
        Dell Latitude 5501 LA-H181P shorted power rail
        by guizmo1967
        This is my problem:
        Laptop: Dell Latitude 5501
        Motherboard: EDC51 LA-H181P
        I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
        I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
        I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
        I injected +1.05V - 2A...
        07-25-2023, 06:56 PM
