I was fixing this for someone and the laptop originally had a backlight problem and i resolved it. then the person tried to replace the keyboard and must've shorted something because now it shows no signs of life. the backlight issue was pretty easy because the burned mosfet on the graphics card was very noticeable. i can't find any shorted caps anywhere on it. the 16v rail and the 3v and 5v rail are there. I need someone give me clue as to what might be missing or shorted
la-g881p area 51m no power
by mkdjDear all,
I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
I have checked resistance across each of the 4 MOSFETS. I have the following readings:
Both N-Channel Mosfets: nothing odd
P-Channel MOSFET number 1:
source - drain : 117 kOhm
source - gate: 96 Ohm
gate - drain: 117 kOhm
P-Channel MOSFET... -
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by abajorI haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
It draws 1.86A injecting directly to ground.
Is this just the way it is when these ultra...03-19-2025, 03:23 AM -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... - Loading...
