820-00165 no power, 08-80ma, PM_SLP_S4_L is pulsing.
  • Wachenaggo
    • Jul 2018
    • 66
    • Philippines
    First is i got this A1466 13” MacBook Air 2017 no power with power draw of 08-80ma. PM_SLP_S4_L is pulsing, If i remove R8111 and PM_SLP_S4_L comes back. no short on RAM power supply then i somehow maybe shorted the U5460 while probing removing the R7450 then i replace it from a donor i still get the pulsing PM_SLP_S4_L. then i tried to Flash a Working BIOS then boom it turned on so assemble it back then Stress test like heaven benchmark then turned on and off restart like basic testing it all passed then i just set aside for like 3 days then after that i checked it again boom its back to its problem again same power draw and pulsing. what did i do wrong?? bios again is corrupted?? i did nothing while its in the shelves??
  • DanielDacko
    • Mar 2015
    • 325
    • Macedonia
    Re: 820-00165 no power, 08-80ma, PM_SLP_S4_L is pulsing.
    Had this problem with this board many times, change bios chip, they are very prone to failure.
    I don't provide help for people using CH341A and a clip.
    • reformatt
      • Feb 2020
      • 1404
      Check for corrosion on the JTAG connector (J6100), that's a more likely cause. Also check termination resistors for corrosion etc around U6100 and the connecting resistors to the CPU (around middle of the board under the RAM). Can't say I've ever had a SPI BIOS chip go bad on these.
      • emoniz
        • Aug 2012
        • 29
        • Portugal
        HI!
        I also had many voltages pulsing, isolated many of them. It didn't have water problems.
        After reading many posts in many forums, i also read about bad bios and the possible symptom that the voltage is pulsing every 2sec. when i'm going to check the bios IC to replace with another, i saw a very tiny IC (U6101) right before the Bios IC that had debris all around it like it has taken water spill only in its body. I had to remove it, clean the board and decontaminated the IC pins with flux. After resoldered the board came back to life.
        Thanks Everyone!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
        • Goldwing1973
          Sonos Play 1 pulsing power supply
          by Goldwing1973
          I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
          So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
          Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
          The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
          But, whats is not normal is the pulsing of resistor...
          07-04-2025, 12:59 PM
