MacBook Air 2018 A1932 820-01521 Not turning on.
  • sikocan
    • Oct 2019
    • 344
    MODEL: MacBook Air 2018 A1932 820-01521
    Problem: 5.12V / 0.60Amps
    History: Unknown but I can see slight liquid spill on IC U8201/74aup1t97gm
    Things tried: I've cleaned the liquid area, removed the IC U8201/check pads, good/ chip looks good, put back. Replaced CD3215C x 2 times, so 4 new chips just in case. I've attached photo readings of V/resistance and signals as per logi wiki website. Please advise what I can check next. Schematics available upon request.
  • mon2
    • Dec 2019
    • 14205
    Re: MacBook Air 2018 A1932 820-01521 Not turning on.
    Each CD3215 controller (U3100 / U3200) must be working before the 20V can be enabled.
    https://repair.wiki/w/A1932_2018_-_2019_MacBook_Air
    * voltages on the CD3215 look ok - the BMC rail will be enabled for the port used to power the logic board.
    1) Check the voltage of PPBUS_G3H.
    2) Check the voltages of the I2C bus lines that mate with the U3100 & U3200 via the TBT bridge.
    • MobileXT
      • Oct 2012
      • 198
      0.60Amps looks like there's a short on the board somewhere. check all the power rails one by one. If you have infrared camera make it easier to locate the shorted caps.
      • sikocan
        • Oct 2019
        • 344
        1) PPBUS_G3H 12.17V.
        2. All are 0V. Resistance of them for your refence:
        I2C_TBT_X_SDA 32K Ohms increasing
        I2C_TBT_X_SCL 32K Ohms increasing
        I2C_TBT_XA_INT_L 3.63M Ohms
        I2C_TBT_XB_INT_L 3.63M Ohms
        I have reflashed the TBT ROM. No change.
        Voltages on TBT ROM CHIP:
        1. 3.26
        2. 3.26
        3. 3.26
        4. Ground
        5. Clock
        6. 1.18
        7. 3.26
        8. 3.26
        • ugamazing
          • Jun 2013
          • 165
          • usa
          I haven't read *every* detail in your posts, but I will mention: Make sure you try several USB-C port assemblies. We had an A1932 unit this past week that was cracked/severed on one of the bends. Just noting this in case you hadn't.
          • mon2
            • Dec 2019
            • 14205
            Your ppbus_g3h rail is low. SMC has not yet boosted it.
            Can you attach the battery to see if it helps?
            Check the I2C lines on the isl device for the ppbus_g3h rail. Check the voltage of SCL and SDA.
            • sikocan
              • Oct 2019
              • 344
              Hi mate,
              Thanks for your help so far.
              From the IC U7000 ISL9240HI
              PIN:
              SDA & SCL is 1.8V
              ppbus_g3h 12.269
              • sikocan
                • Oct 2019
                • 344
                With the battery it was the same situation.
                • mon2
                  • Dec 2019
                  • 14205
                  Voltage of PP3v3_G3H_RTC ?
                  • sikocan
                    • Oct 2019
                    • 344
                    PP3v3_G3H_RTC is 3.14V
                    • mon2
                      • Dec 2019
                      • 14205
                      The last measurement is considered to be too low.
                      Is the meter being used accurate?
                      From repair wiki...
                      The most common reason for PP3v3_G3H_RTC to be missing or low, is a short to ground, usually on a capacitor around one of the CD3215s.
                      Locate where this rail travels on the CD3215.
                      Remove all power and check the resistance to ground of this rail. What is the resistance?
                      As a test, remove the cap(s) on this rail near the CD3215. Then check the voltage again. It should be higher to allow the cd3215 to function properly.
                      • sikocan
                        • Oct 2019
                        • 344
                        PP3v3_G3H_RTC goes to pin 62 of u3200, pin 62 on u3100
                        Both readings are hard to focus on, but resistance mode is varies between 5kohms to 1.5M ohms between.
                        • sikocan
                          • Oct 2019
                          • 344
                          Removed caps on both c3100 and c3200
                          Same result
                          • sikocan
                            • Oct 2019
                            • 344
                            PP3v3_G3H_RTC is now 3.2928
                            • mon2
                              • Dec 2019
                              • 14205
                              Good. Now this is the expected voltage. One of the removed caps must have been bad.
                              What is the voltage now of ppbus_g3h ?
                              Check voltage of PPDCIN_G3H on each of the ports (cd3215).
                              • sikocan
                                • Oct 2019
                                • 344
                                I'll now replace both caps and test again
                                • sikocan
                                  • Oct 2019
                                  • 344
                                  ppbus_g3h 12.268v
                                  PPDCIN_G3H 5.122v
                                  I've replaced both caps.
                                  • mon2
                                    • Dec 2019
                                    • 14205
                                    Measure the voltage of:
                                    PP3v3_UPC_XA_LDO
                                    PP3v3_UPC_XB_LDO
                                    • sikocan
                                      • Oct 2019
                                      • 344
                                      PP3v3_UPC_XA_LDO 3.33
                                      PP3v3_UPC_XB_LDO 3.26
                                      • mon2
                                        • Dec 2019
                                        • 14205
                                        Good voltage.
                                        Attempt the following:
                                        Revive T2 firmware via Apple Configurator 2
                                        Reference:
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • Clarify4082
                                          Macbook Air 2018 A1932 Bootloop
                                          by Clarify4082
                                          I have a A1932 Macbook Air with Bootloop.
                                          I already replaced the battery with a new one and reset NVRAM and SNC.
                                          When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
                                          If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
                                          01-07-2025, 09:41 AM
                                        • bouch
                                          unlock macbook air A1932 2019
                                          by bouch
                                          hi
                                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                          I need help or information?
                                          Does anyone have the minat2 activator 1.4 software?
                                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                          Thank yo...
                                          03-12-2025, 10:14 AM
                                        • reessi
                                          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                          by reessi
                                          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                          No corrosion any where!
                                          Tried a replacement power button off ebay and the same.
                                          Very occasionally it will work with the power button connected!
                                          Same results with or without the battery.
                                          Can it be a fault with the Audio board or the mainboard?
                                          The touch Id assembly connects through the Audio board first then to the Mainboard.
                                          Flex...
                                          06-26-2024, 03:31 PM
                                        • mitchw
                                          MacBook Air 2018 A1932 820-01521 stuck at 5V, but succesfully does the DFU and boots into OS installer
                                          by mitchw
                                          I have a 820-01521 that is stuck at 5V, and drawing just 230mA.
                                          I did some troubleshooting, and managed to charge the battery up (was at 0%) using a different logic board.
                                          Also I ran DFU and it did it successfully. Had to use a PMU_FORCE_DFU jumper to do it.
                                          At this point the laptop started up and it successfully boots into the OS Install.
                                          The charger is now at 20V, but drawing 0mA, so the laptop is essentially running off the battery. It doesn't detect the charger...
                                          I think there could be a problem with one of the CD3215s, but all the LDOs are the...
                                          01-04-2024, 01:47 PM
