Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
  • IamPritesh
    • Aug 2017
    • 356
    • India
    So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
    ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
    What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
  • mon2
    • Dec 2019
    • 14725
    Re: Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
    According to another post on this forum, the IC is compatible. Be sure it is soldered in OK and without any shorts.
    Does the laptop work OK with ONLY the AC adapter ? (no battery connected)
    If yes, we need to review the battery mosfet and the charger interconnect side of the logic board.
    Start with, remove all power / no battery.
    Meter in resistance mode.
    Measure the resistance of the dcin mosfet @ PQ35 as follows:
    Source (1-2-3) & drain (5-6-7-8)
    Source (1-2-3) & gate (4)
    Gate (4) & drain (5-6-7-8)
    Post each measurement and the meter scale used.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Yes the laptop works fine on adapter only mode. Will post dcin fet resistance tomorrow morning. Thanks
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Applied some more heat to the newly replaced charging IC ISL88731 and now it works fine on battery as well. Thanks everyone.
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • tec3000
          Sony LED 65X9005A shuts down after few seconds - looking for help
          by tec3000
          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
          03-20-2024, 07:29 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • redbaron1007
          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
          by redbaron1007
          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
          09-09-2025, 11:10 AM
