Anyone know how to determine RAM/SSD configuration on dead 820-01958?
  • ugamazing
    • Jun 2013
    • 171
    • usa
    I'm hoping to find a way to easily (and reliably) determine the RAM/SSD configuration of a dead board--in this case, an 820-01958.
    I've checked all over the board for any configuration codes to compare to the schematic BOM info pages, but no luck. Chip markings not useful; I can pull some ROM dumps if anyone know which one may include configuration info. Maybe the T2 ROM? May try to compare RAM configuration resistors as on older 00165 boards, but hoping there's an easier way before doing that.
    Curious if anyone may know this. Would be very helpful for us; thank you in advance!
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Re: Anyone know how to determine RAM/SSD configuration on dead 820-01958?
    OK, I think I got the RAM figured out via RAMCFG info:
    I believe that if a board has R1490 or R1492 populated, it's 16GB. If a board has NOSTUFF for R1490 and R1492, it's 8GB.
    Someone can correct me if I'm wrong.
    • mon2
      • 14662
      Hi
      Search for 'strap' keyword -> look at the DRAM strap table.
      8GB = 8 GB of RAM onboard.
      16GB = 16 GB of RAM onboard.
      That is last conclusion we came up with and hope to 'soon' perform upgrades with our BGA rework table. Ironically, we received a board back that we shipped overseas for a 16GB upgrade (iMAC A1418) so very very likely it is the upgraded ram that is the fault.
      The iMAC LED pattern is:
      1 - solid on = AC ok.
      2-3 blink and then repeats so failing the RAM test.
      Was out in the field for ~6 months.
      We will reflow the BGA DRAM devices.
      • ugamazing
        • Jun 2013
        • 171
        • usa
        Thanks, mon!
        Yes, now trying to identify the SSD capacity externally. Primary reason is for replacing dead customer boards for retail/insurance purposes. We can certainly "ask the customer", but that would leave room for...dishonesty, lol. I have a feeling every customer will say they had 512GB+ of course, haha!
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • fixitforfree
          Samsung TV mu6179 with Mainboard BN41-02568B wont save configuration.
          by fixitforfree
          I have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
          Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different...
          07-21-2025, 09:07 AM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
        • zunasthegreat
          Chieftec GPS-450-AA with dead 20N60C3
          by zunasthegreat
          Hello everyone hope all doing well!
          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
          09-01-2024, 07:12 PM
        • Beton
          Finding a dead short component
          by Beton
          Hi guys!
          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
          I have a bench PSU and if I try to inject voltage the voltage...
          12-10-2021, 01:05 PM
