hp 8560p proplem please help
  • doctormasry
    • Dec 2019
    • 108
    • giza
    hi
    i ve hp 8560p with problem
    when i remove ram . lap work fine ( sure no display ) but fan turn normal and no start . and cup get normal hot
    when i connect ( put) ram fan turn high sound and laptop always restating
    change more than 10 ram no new
    flash bios no new
    coil L3201 1.5 volt
    but when i remove ram ( laptop) without ram i measure Q3202 fount D 1.4 - S 1.4 G = 0
    put when i put ram in socket D = 1.4 - S = 0 - G = 0
    changed this mosfet no new
    there is no schematic for this model
    please help
  • mon2
    • Dec 2019
    • 14672
    Re: hp 8560p proplem please help
    What are the silk screened markings on the logic board?
    Can you post pictures?
    Without ram, do you hear any post beep codes? Any blinking led pattern to note that the ram is missing?
    • doctormasry
      • Dec 2019
      • 108
      • giza
      this is the motherboard photo
      in the picture number 11 . the led number 1 always on with ram but without ram on for 1 sec and off
      led 2 and 3 alwyas on with ram or without ram
      this mosfet measure without ram
      but with ram no volt on source
      i just have only motherboard no more
      • doctormasry
        • Dec 2019
        • 108
        • giza
        can any one tell me the most important pins on ram ddr3 socket ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          VRef_DQ =PIN 1
          VTT/Termination voltage=PIN 203,204
          VRef_CA. =PIN 126
          VDD SPD =PIN 199
          SDA data =PIN 200
          SCL clock =PIN 202
          DRAM_RST# =PIN 30
          • Udemzy
            • May 2017
            • 164
            • Guatemala
            Do a clean me region or flash a new BIOS, that's the first thing you should do
            • ash91
              DELL INSPIRON PS_ID PROPLEM AND FIX
              by ash91
              Hi
              I had a nice dell laptop yesturday,the proplem was it is not charging...
              i try another orginal charger with no luck also another battery no change either
              the famus massage that the ac adapter wattage in not reconize by the laptop always show at the boot
              in the bios the ac adpters is unkhown
              so it is a motherboard issu, first i download a boardview to know what i am abut to deal with
              then i extract the motherboard to start trace the voltage
              the 19.5 line was ok but the ps_id was 4.2v it shuld be 3.3
              the signal came from super io chip so that where...
              12-22-2023, 02:25 PM
            • blazzelia
              HP Elitebook 8560p - sudden power off
              by blazzelia
              Hi guys,
              I have an HP Elitebook 8560p which works for a while, then suddenly powers off.
              I check the MB and I found a small cap exploded near a 6912 MOSFET (there were 3 such caps in parallel). I replace it with a 2 uF cap and the interval of power off events increased a lot. Initially the laptop was stopping at, in average, every 15-20 minutes, now it works for hours but it still stops once or twice per day.
              I also replaced the 6912 MOSFET but it did not made any difference.
              Unfortunately I don't have and could not find a schematic for this laptop so I'm...
              10-24-2022, 02:37 PM
            • sonerpc
              nm-c171 rev:1.0 s145-ast backlight proplem
              by sonerpc
              On the s145-ast lenovo laptop with nm-c171 rev:1.0 motherboard, the image appears without illumination. When I look carefully, I can see the lenovo text. I downloaded the bordviewer and the schematic from the badcaps family, but which voltages should I measure? 20 volts come out from both ends of the fuse.
              07-15-2024, 05:47 AM
            • bembeno
              hp 8560p no display - volts on cpu coils
              by bembeno
              hp 8560p uma no volts on cpu coils
              cpu controll is max 17511
              can any one plz explain whats the requirement to this ic to startup
              05-22-2022, 03:43 PM
            • sonerpc
              Lenovo lv315kb mb 17807-3 proplem
              by sonerpc
              The problem with this motherboard model is the video card. When the video card driver is installed, the device freezes. Is there a possibility to cancel the video card in this motherboard model. Or is there a software that will cancel my external video card via bios?
              03-02-2023, 06:53 AM
