HP 15-dc DAG3DDMB8C0 problem power up with battery.
  • quic307
    • Jun 2015
    • 257
    • Greece
    Hi techs,
    I have the HP 15-dc DAG3DDMB8C0 rev C.
    When I have the battery (without the power adapter) it doesn't power up. The first time I put the new battery in it will power up, but after few seconds nothing. I insert a second new battery and after few second same ...
    I'm looking for a short circuit, I can't find it.
    With the power supply is fine but it does not charge the battery.
    I need help please ...
    Thanks a lot...
  • mon2
    • 14667
    Re: HP 15-dc problem power up with battery.
    Link the schematic if available.
    Post the voltage with the adapter and battery connected of every pin on the battery connector. Start here.
    • quic307
      • Jun 2015
      • 257
      • Greece
      No shematic available
      I made 3 measurments with the adapter connected
      with "new" battery
      pin1 Gnd
      pin2 Gnd
      pin3 0
      pin4 3,13
      pin5 3,10
      pin6 3,10
      pin7 13,8
      pin8 13,8
      without battery
      pin1 Gnd
      pin2 Gnd
      pin3 3,15
      pin4 3,27
      pin5 3,21
      pin6 3,21
      pin7 3,08
      pin8 3,08
      with the old dead battery
      pin1 Gnd
      pin2 Gnd
      pin3 0
      pin4 3,29
      pin5 3,13
      pin6 3,13
      pin7 1,11
      pin8 1,11
      So pins 5 & 6 are the data communication pins and they are stable [they both have the same value of resistor connected]
      pin 4 seems to be different from pins 5 & 6 as it has a low resistor [just 100 Ohms] - maybe is for suppling the 3 volts olny?
      pin3 is the battery detection pin and goes to zero when battery is present - it connects to pin120 of kbc
      pin7 & 8 are the positive of the battery, non of the two batteries gives voltage without the power adapter and when connecting the power they take different charge voltage in order to charge but they don't as voltage remains stable
      • mon2
        • 14667
        The mosfets mated with the charger IC need to be reviewed. While they are passing through the voltage to the logic board, you likely have defective mosfets.
        Look near the dcin adapter connector to locate the battery charger. What are the markings on the topside of the charger IC?
        Start with, remove all power / no battery.
        Meter in resistance mode.
        Measure the resistance of each of the 2 x dcin mosfets as follows:
        Source (1-2-3) & drain (5-6-7-8)
        Source (1-2-3) & gate (4)
        Gate (4) & drain (5-6-7-8)
        Post each measurement and the meter scale used.
        Repeat for the next mosfet.
        You will find 3 other mosfets that will be for the battery charging and that connects the battery to the logic board.
        Also interested in the measurements of those mosfets which are high side, low side and battery mosfets.
        One or more of these is leaking. The measurements will tell us which one is defective.
        No power when checking the resistance values.
        • quic307
          • Jun 2015
          • 257
          • Greece
          the charger is BQ24738H
          meter has auto scale, 2 measurements by flipping positive & negative probes
          first dcin mosfet [2 in parallel]
          S & D 7,25M 4,45M
          S & G 10,77M open line
          G & D 23,27M open line
          second dcin mosfet
          S & D 3,91M 3,43M
          S & G 10,73M open line
          G & D 15,06M open line
          high side charge
          S & D dropping from over 10M close to 6M either side
          S & G 193K 48K
          G & D 2,3M droppin around 5M
          low side charge
          S & D 6,8M 5,1M
          S & G 142K 46K
          G & D 4,3M 5,5M
          battery mosfet
          S & D 1,05M dropping from over 10M close to 6M
          S & G 6,6M open line
          G & D 2,7M open line
          at all battery mosfets the measurements constantly change more or less
          • mon2
            • 14667
            Replace your high side and low side battery mosfets and test again. The resistance in the low kohms is considered too low.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I dont think High/Low side fets are defective. Better if you can give voltage on all charging Pins.
              • quic307
                • Jun 2015
                • 257
                • Greece
                I change battery from other store and now works.
                Thank you for your time.
                • mkdj
                  by mkdj
                  Mark and model: ASUS X571
                  Tests already made:
                  - I have removed...
                  07-14-2025, 09:16 AM
                • DenK
                  Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                  by DenK
                  Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                  1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                  12-06-2024, 01:29 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • Gust zhang
                  Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                  by Gust zhang
                  ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                  02-16-2025, 08:39 AM
                • survivalbloke
                  Acer Predator Helios 300 - will not power up if battery is CONNECTED
                  by survivalbloke
                  This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                  06-25-2025, 12:20 PM
