Hp compaq nc6400 hatoo la-2951p power issue
  • vettouch
    • Sep 2020
    • 68
    • Nigeria
    I have this laptop that suddenly developed some power faults. The adapter gives the normal rated voltage, but if it is connected to the board, there is no 3.3v or any other voltage. some few resistors and capacitors near the PCN1 have their values below their rating on the board but off-board, they read normal. Also, PL1, PQ3, PQ4 are getting very hot. How can I test and isolate the fault? See the schematic I am working with. My board screenshots also attached.
  • mon2
    • Dec 2019
    • 14170
    Re: Hp compaq nc6400 hatoo la-2951p power issue
    You are on the right part of the review - PQ3 and PQ4 are the usual suspects - see the detailed thread above from @Piernov.
    Remove all power / no battery.
    Meter in resistance mode.
    Check the resistance across each mosfet:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post the reading in ohms and also the scale used for the measurement on your meter.
    Repeat for PQ4. Very likely that at least one or both of these mosfets is defective. If available, you can skip ahead and replace them both for testing.
    Also, on the charger IC (PU2), post the voltages for:
    ACDET (pin # 26)
    ACDRV# (pin # 25)
    • vettouch
      • Sep 2020
      • 68
      • Nigeria
      @MON2
      readings on metre
      @200 ohm, 2000 ohm & 20k ohm, no reading between source and drain pins.
      @200k ohm; (1,2,3) and (5,6,7,8) = 69.8
      @2000k ohm (1,2,3) and (5,6,7,8) = 69
      @2000k ohm (4) and (5,6,7,8) = 271.
      I had replica MOSFETS which I used in replacing PQ3 and PQ4, yet, no results (still very hot).
      No voltages on ACDET (pin #26) and ACDRV# (pin #25)
      After replacing PQ3 and PQ4, mosfets are still hot.
      What else do I check and I
      • mon2
        • Dec 2019
        • 14170
        Remove PQ4 - power up again.
        Are PL1, PQ3 now cool ?
        • vettouch
          • Sep 2020
          • 68
          • Nigeria
          @mon2
          Yes, PL1 and PQ3 now very cool.
          • mon2
            • Dec 2019
            • 14170
            Ok. Meter in resistance mode (start with the lowest scale).
            Check the resistance to ground of pins 1-2-3 of the REMOVED Q4 mosfet.
            We are checking if there is a shorted part on the main rail.
            Also check the resistance to ground of pins 5-6-7-8 of mosfet @ PQ7.
            Post the measurements and scale used on your meter.
            • vettouch
              • Sep 2020
              • 68
              • Nigeria
              @mon2
              MY METRE IN RESISTANCE MODE
              check: resistance to ground
              PQ4
              @200 OHM; pins (1,2,3) = 1.3ohm each
              @2000ohm; pins (1,2,3) = 1ohm (001 on metre)
              @20k ohm; pins (1,2,3) = 0.01 ohm each
              @200k ohm; pins (1,2,3) = 00.0 ohm each
              @2000k ohm; pins (1,2,3) = 000 ohm each
              PQ7
              @200 ohm; pins (5,6,7,8) = no reading
              @2000 ohm; pins (5,6,7,8) = 511
              @20k ohm; pins (5,6,7,8) = no reading
              @200k ohm; pins (5,6,7,8) = 71.6
              @2000k ohm; pins (5,6,7,8) = 048
              • DanielDacko
                • Mar 2015
                • 325
                • Macedonia
                Originally posted by vettouch
                @mon2
                PQ4
                Inject 1V on pins 1,2,3 with lab PSU and see what heats up. Probably some ceramic capacitor.
                I don't provide help for people using CH341A and a clip.
                • vettouch
                  • Sep 2020
                  • 68
                  • Nigeria
                  @DanielDacko
                  I don't have Lab PSU.
                  • vettouch
                    • Sep 2020
                    • 68
                    • Nigeria
                    @DanielDacko. As I don't have Lab PSU, what alternative using multimetre will I use to diagnose?
                    • DanielDacko
                      • Mar 2015
                      • 325
                      • Macedonia
                      Multimeter won't help you in this case and it's just time wasting, fastest way is injecting voltage on the shorted rail. What can I tell you except to get lab psu or remove part by part to see when the short is gone. You can't use desktop psu since this is a dead short and the psu won't even start.
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • justice171
                        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                        by justice171
                        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                        1. Verified that all critical voltages are present:
                          • 3.3V and 5V are always present if DC is plugged.
                          • 1.8V on the BIOS chip is present.
                        2. Checked the power button functionality:
                          • When pressed, the voltage drops to 0V, indicating the button is functional.
                        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                          • Confirmed connectivity is intact, ruling out issues
                        11-26-2024, 12:39 AM
                      • claws77
                        lenovo flex 5 14itl05 power sequence issue
                        by claws77
                        hi guys, my motherboard will not start no matter what
                        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                        but rest nothing happens no sign of life.
                        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                        i have no knowledge of motherboards ....
                        10-20-2024, 02:48 PM
                      • SuperJames
                        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                        by SuperJames
                        This one's a weird one, and still unsolved despite it having gone back to Dell once.
                        Specs
                        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                        Backstory
                        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                        10-23-2023, 04:09 PM
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
