Acer aspire one not power on
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Acer aspire one (LA-5141P, KAV60) not getting powered-on,. Any guidance please.
    Some testing are:
    Rtc Crystal and IO crystal 32khz ok
    3v & 5v ok, VL ok
    Cmos battery removed
    Before pressing, dc supply shows 0.002A
    after pressing power button led on it glows for few seconds then off and board does not power-on
  • mon2
    • Dec 2019
    • 14371
    Re: Acer aspire one not power on
    See attached. Review the details of PQ10 DCIN mosfet.
    Post the voltages on the pins shown with the arrows.
    Next, remove all power -> check the resistance across the mosfet pins.
    See the many other threads here on how to test the resistance to confirm if the mosfet is defective or not.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      What is the consumption when u turn on? I'm interested in the variation of consumption between on and off mode. What rails are coming up and what not(after pressing power switch)??
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        Sir, on PQ10 DC IN mosfet:
        Voltages on
        Source: 19.7
        Gate. 7.8
        Drain. 19.7
        Resistence: on 200k settings:
        Drain & source 44.3 k
        Source & gate 81.6 k
        Gate & drain (on 2M setting): 590 k
        • usyusy
          • Sep 2021
          • 171
          • Pakistan
          Sir, when turn on (which sometime not so have to unlpug and then plug to be able to trigger)
          Only 0.03A and then again on 0.02A.
          Only 19v, 3v and 5v available before and after pressing power button no other voltages show on any other coil.
          • mon2
            • Dec 2019
            • 14371
            Replace PQ10. The resistance is too low to be a good mosfet.
            • usyusy
              • Sep 2021
              • 171
              • Pakistan
              Replaced with a scrap board mosfet
              Drain & source 49.6k
              Gate & source 81.6k
              Gate & drain 640k
              • mon2
                • Dec 2019
                • 14371
                Measure the resistance of the removed mosfet while it is off the logic board.
                Post the readings.
                • lapfix
                  • Mar 2020
                  • 2744
                  • my workshop
                  Why yo judge that's not perfect !!
                  how much will be find to be sure !
                  • mon2
                    • Dec 2019
                    • 14371
                    See here:
                    http://electronicsbeliever.com/how-t...-is-defective/
                    • lapfix
                      • Mar 2020
                      • 2744
                      • my workshop
                      yes i know this site , it was a nice advice from you from another thread....but still confuse , the reading of usyusy are perfect to me...did you compare it with another same mosfet or from mosfet datasheet
                      • mon2
                        • Dec 2019
                        • 14371
                        No. Do not have these parts here but expecting a much higher resistance reading for the same measurements (100kohms++).
                        Since the resistance checks are similar for both parts on the logic board, the mosfet may be ok but let us wait on the OP to post the resistance values of the mosfet while it is out of circuit.
                        The support components on the logic board may be influencing the resistance values.
                        • usyusy
                          • Sep 2021
                          • 171
                          • Pakistan
                          Drain & source 44.7k
                          Gate & drain & source showing 1, not any movement on multimeter
                          • mon2
                            • Dec 2019
                            • 14371
                            IMHO - the resistance is too low for source & drain. Is it possible that the replacements were also defective ?
                            Would you have fresh mosfets you can test here ? Before soldering them, check their resistance while they are out of circuit.
                            • usyusy
                              • Sep 2021
                              • 171
                              • Pakistan
                              Replacement done with another mos
                              Drain & source 322 k
                              Gate & drain 588 k
                              Gate & source 197 k
                              • mon2
                                • Dec 2019
                                • 14371
                                Ok. What mosfet was used for the replacement ? Share the part number.
                                With the new mosfet, what are the results ?
                                What are the voltages on the source, gate, drain pins of this mosfet ?
                                • usyusy
                                  • Sep 2021
                                  • 171
                                  • Pakistan
                                  Its was Pbyhd fds 6679az something written on it, pic attached
                                  Results are same
                                  Voltage :
                                  Source 19.7v
                                  Drain. 19.7v
                                  Gate. 7.7v
                                  • mon2
                                    • Dec 2019
                                    • 14371
                                    So the voltage is passing between source & drain.
                                    Do you always see the voltage on both sides of the mosfet ? Or does it power OFF after a few seconds like before ?
                                    What is the voltage of the main rail @ CHG_B ?
                                    While the power rail is ON, check the voltage of each inductor to confirm that each respective power rail is working.
                                    Report any 0 volt or low voltage rail that may be faulty.
                                    Any liquid damage ? Just stopped working one day ? Using the original power adapter ?
                                    • usyusy
                                      • Sep 2021
                                      • 171
                                      • Pakistan
                                      yes sir on both sides of mosfet the voltage seems always, CHG_B main rail shows 19.5v, before and after power button press only 3v,5v rails remains on no other rail appears on any inductor, board showed some carbon around IO, so washed , yes just stopped one day, using original adapter even dc supply was used.
                                      • mon2
                                        • Dec 2019
                                        • 14371
                                        Does the gate voltage change on PQ10 mosfet when you press the on/off button ? It should to allow for the logic board to turn ON/OFF.
                                        The io controller may need to be reprogrammed or replaced but no experience in that area.
                                        For the coils that have no voltage, remove all power and check their resistance to ground. This will check for shorted caps.
                                        Post the details.
                                        Wait on other feedback.
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
