Macbook 820-3115B P18V5 issue
  • Nuld_
    • Jun 2022
    • 64
    Hello there,
    So i have a A1278 13" (820-3115-B) which was definitely has been worked on.
    There is definitely an issue on the "P18V5_DCIN" Line.
    Before I´ve connected the Magsafe Connector and something around or on the backside of D6990 was smoking.
    D6990 readings:
    Pin 1: starts at 5Mohms but is declining
    Pin 2: 25,4kohms
    Pin 3: 31kohms
  • mon2
    • Dec 2019
    • 14034
    Re: Macbook 820-3115B P18V5 issue
    Are these the resistance to ground readings for D6990 ?
    Remove all power / no battery.
    Meter in diode mode.
    Check the diodes in the diode mode.
    So red meter lead on pin # 1; black meter lead on pin # 3. What is the reading?
    Now reverse the meter leads and there should be no flow. Reading ?
    Red meter lead on pin # 2; black meter lead on pin # 3. What is the reading?
    • Nuld_
      • Jun 2022
      • 64
      Yes, the readings are to ground.
      Pin 1-3: 0,227V
      Reverse: 0,964V
      Pin 2-3: 0,226V
      Reverse: O.L
      • mon2
        • Dec 2019
        • 14034
        Pin 1-3: 0,227V
        Reverse: 0,964V
        D6990 is defective and needs to be replaced.
        Reverse of 1-3 should be O.L.
        • Nuld_
          • Jun 2022
          • 64
          Removed D6990 readings on Board to ground are:
          Pin 1: starts at 25Mohms but is declining.
          Pin 2: 39,3kohms
          Pin 3: 31,25kohms
          • mon2
            • Dec 2019
            • 14034
            Resistance readings are fine on the logic board.
            Has D6990 been replaced ? Do replace it and measure the DIODE mode readings again. Post the measurements.
            • Nuld_
              • Jun 2022
              • 64
              Diode mode readings with new D6990:
              Pin 1-3: 0,18V
              Reverse: 0,933V
              Pin 2-3: 0,2V
              Reverse: O.L
              So basically the same readings, new D6990 is a know good one.
              • mon2
                • Dec 2019
                • 14034
                Measure in the same way, the removed (older) dual diode that was onboard. Measure while it is NOT on your board.
                What are the readings ? Something else may be wrong but let us confirm.
                • Nuld_
                  • Jun 2022
                  • 64
                  D6990 readings when removed:
                  Pin 1-3: 0,227V
                  Reverse: O.L
                  Pin 2-3: 0,226V
                  Reverse: O.L
                  • mon2
                    • Dec 2019
                    • 14034
                    So the diode is good but something may be wrong with the logic board.
                    Remove F7040 fuse and check the DIODE readings again with the present diode that is onboard. No power during these tests.
                    • Nuld_
                      • Jun 2022
                      • 64
                      Same readings with F7040 detached.
                      • Nuld_
                        • Jun 2022
                        • 64
                        Forgot to mention that U7941 is currently missing on this board.
                        • mon2
                          • Dec 2019
                          • 14034
                          That is ok. Wondering if U6990 is throwing this off.
                          Do you have a donor board ? Check the readings of the same D6990 on another board.
                          You can try to remove U6990 and see if the results improve. The question is why this leg of the dual diode is showing this reading in reverse mode but the other leg is ok.
                          • Nuld_
                            • Jun 2022
                            • 64
                            U6990 Readings:
                            Pin 1: 1,268MOhms
                            Pin 2: O.L
                            Pin 3: 1MOhms
                            Pin 4: 31kOhms
                            Pin 5: 0,1Ohms
                            Pin 6: 31kOhms
                            Pin 7: 31kOhms
                            Pin 8: 31kOhms
                            Pin 9: 31 kOhms
                            Pin 10: 184,5kOhms
                            No donor board which i´m trusting that U6990 is okay.
                            • Nuld_
                              • Jun 2022
                              • 64
                              U6990 seems to be okay
                              • Nuld_
                                • Jun 2022
                                • 64
                                But i´m really confused that Pin 3 Ohms doesn´t change even when D6990 isn´t soldered on.
                                • Nuld_
                                  • Jun 2022
                                  • 64
                                  Anything else I could check for ?
                                  • mon2
                                    • Dec 2019
                                    • 14034
                                    If safe to do so, check of the 3v42 rail is being created by this IC with your magsafe adapter. It is a primary required rail.
                                    If you do not see 3v42, then remove all power and check to see if the output of this IC is being shorted to ground. Check the resistance to ground if the voltage rail is not present.
                                    • Nuld_
                                      • Jun 2022
                                      • 64
                                      The problem is that D6990 only recieves around 4V at Pin 1 and 2 but R6905 or R6990 are totally fine.
                                      • mon2
                                        • Dec 2019
                                        • 14034
                                        Post the voltage readings on each side of the same resistors and voltage on each pin of this dual diode.
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • pcbmaniac
                                          MacBook A1278 (3115) No PPBUS_G3H Issue
                                          by pcbmaniac
                                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                          1. U7000 Measurements:
                                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                          2. Resistors:
                                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                          12-02-2024, 04:12 PM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • Stephen
                                          A2141 MacBook Pro 16" lid sensor issue.
                                          by Stephen
                                          Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                                          11-01-2024, 03:45 PM
                                        • Gueric
                                          MacBook Pro 2019 820-01700 Speaker amp issue.
                                          by Gueric
                                          I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
                                          I don't how to troubleshoot speakers. Any help would be very much appreciated.
                                          A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
                                          05-19-2025, 03:08 AM
