Acer A315-55G / DA0ZAWMB8E0 power button
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    sir, after pressing the power button the volt does not fully down to 0V neither on power-button itself nor on the SIO concerned pin, e.g its decrease to only like 2V, or 1.5 or even 1 etc, what could be the logic ..,regards.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer A315-55G / DA0ZAWMB8E0 not charging [SOLVED]
    A miltimeter may not be able to catch the debounce on power switch . Use oscilloscope to be sure. I think if dmm is showing going down to 1.5 or1V, its working.
    • themosttogain
      HP Envy 13-BA1565na with intermittent power button
      by themosttogain
      Hope someone can give me some suggestions on this because i'm at my wits end with it...
      I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
      Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
      07-12-2024, 03:03 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • TimeRabbit07
      Asus FX517ZC charges but power button does nothing
      by TimeRabbit07
      Hi all!
      I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
      Here are its various numbers and identifiers:
      Model short: FX517Z
      Model long: FX517ZC-HN114W
      SN: NANRCX01S57842E
      CN: 3SDB 12M
      MFD: 2022-10
      Motherboard model: DA0NJLMBAE0 REV E
      Symptoms:
      The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
      History so far:
      The...
      09-04-2024, 05:48 PM
    • reessi
      Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
      by reessi
      With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
      No corrosion any where!
      Tried a replacement power button off ebay and the same.
      Very occasionally it will work with the power button connected!
      Same results with or without the battery.
      Can it be a fault with the Audio board or the mainboard?
      The touch Id assembly connects through the Audio board first then to the Mainboard.
      Flex...
      06-26-2024, 03:31 PM
    • Bonaventure Vigil
      ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
      by Bonaventure Vigil
      Dear All,
      Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
      At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
      12-12-2024, 10:22 AM
