IC Marking Codes and Datasheets #2
  • javieromex
    • Apr 2016
    • 83
    • México
    #121
    Looks pretty similar, however, SY8371B might be 3V (see attached only information I was able to find, only 11 pages).
    • mon2
      • 14673
      Check your pm. Sent you the full data sheet.
      • mferna14
        • Jun 2018
        • 1046
        Dear friends, I am working on Lenovo Yoga 7 14IRL8, no schematic available. Upon trouble shooting I found this chip shorted. There is a code marking S2=AB on this chip, but could not find this marking (View Photo). I thnk this chip is soldered on the 3.3V or 5v rail. Can someone help me finding the real number of the chip. Thanks in advance.
          • 21932
          When the marking has an = its probably a richtek part https://www.badcaps.net/forum/troubl...19#post1482819 Google search - richtek S2=
          How many pins does it have,it might be a RT6310CGQUF https://www.richtek.com/assets/produ.../DS6310-04.pdf
          • mferna14
            • Jun 2018
            • 1046
            "SMDFlea", it's 23pin & I think this is the same chip,, the link you have send me. Thank you so much.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8340
              Originally posted by SMDFlea
              Re: IC Marking Codes and Datasheets #2
              GStek
              Datasheets & Other Info
              Green Solution Technology Co., Ltd. (GStek), a partner of the NIKO-SEM Group
              Datasheets http://www.gstekic.com/product_list_en.php
              Marking list
              Note:Some marking codes might not be accurate,need to confirm !!!!
              __________________________________________________ ________________
              Part Number...................Marking.......Example..........Package
              GS7108ST-3P3-R............ AHRV*......... AHRVL ............SOT-23-5
              GS7119ST-3P3-R.............ARRV*..........ARRVS.............SOT-23-5
              GS7119ST-1P8-R.............AREV*..........AREVQ.............SOT-23-5
              GS7119-AST-1P8-R..........ARE*W.........AREUW............SOT-23-5
              _
              GS7116S5-ADJ-R.............4ba*.............4baA.................SOT-23-5
              GS7118S5-3P3-R.............E5***............E5R2S..............SOT-23-5
              GS7612S5MA-R..............ELM**...........ELMAB.............SOT-23-5
              GS7138S5-3P3-R............Q5R**...........Q5RGC..............SOT-23-5
              GS7117S5-105-R.............UW**............UWRV...............SOT-23-5
              Examples
              GS7119ST-1P8-R
              Datasheet: https://cdn.badcaps-static.com/pdfs/...4a804f71d4.pdf
              Picture from lcsc.com.
              This examples typical application picture and pin out doesn't fit the pictured LDO. It's for a different package.
                • 21932
                Ah, you`re right it doesn`t, thanks for pointing out the mistake. I didn`t check the typical application picture against the different package pin configurations. I`ll remove that picture.
                • py2eb
                  • Mar 2022
                  • 14
                  • Brasil
                  #128
                  Hello friends.
                  Can any colleague identify this component? BJE*
                  It's from a Positivo Motion GRAY C4128G-14 Board EM_G8319_96B_V1.0​
                  • mon2
                    • 14673
                    5-10Pcs NB687BGQ-Z Silkscreen BJEN BJEM BJE* Patch QFN-16 Management Chip IC - AliExpress 502
                    • py2eb
                      • Mar 2022
                      • 14
                      • Brasil
                      #130
                      • magneh
                        • Apr 2014
                        • 616
                        • Portugal
                        #131
                        Need help from the IC's experts
                        Got a Devialet Phantom reactor 2 with no power.
                        Was able to open this device with a lot of pain, but now I need to identify this IC.
                        The original IC is burned and I can only see a "|" at the beginning of the ic.
                        I found other IC , also 5 legs, that also starts with | but im unable to identify.
                        Pics attached.
                        Thanks for any help!
                        • mon2
                          • 14673
                          10PCS/Lot TPS71501DCKR ARB、TPS71525DCKR AQL、TPS71530DCKR AQM、TPS71533DCKR AQI SC-70-5 New original boost LED driver - AliExpress 502
                          TI Part # TPS71501DCKRM3
                          TPS715 50-mA, 24-V, 3.2-μA Quiescent Current, Low-Dropout Linear Regulator datasheet (Rev. T) (ti.com)
                          TPS71501DCKRM3 Texas Instruments | Mouser
                          • xuandan
                            • Sep 2017
                            • 19
                            • viet nam
                            #133
ID:	3471376 hi all . Can any colleague identify this component?
                            • Bonzas
                              • 474
                              • Indonesia
                              #134
                              Originally posted by xuandan
                              Click image for larger version  Name:	screenshot_1727687773.png Views:	0 Size:	56.7 KB ID:	3471376 hi all . Can any colleague identify this component?
                              Richtek Product
                              RT8884B
                              Datasheet
                              https://www.richtek.com/assets/produ...DS8884B-01.pdf
                              • xuandan
                                • Sep 2017
                                • 19
                                • viet nam
                                #135
                                Originally posted by Bonzas
                                thanks
                                • py2eb
                                  • Mar 2022
                                  • 14
                                  • Brasil
                                  #136
                                  Originally posted by abouterfan
                                  hey everyone,
                                  FRCXA can anyone mark this ic please?
                                  thiis ic is on the harman kardon onyx studio 5 board
                                  FR*** => SY7901_ DFN3×3-10
                                  https://www.huanqiuic.com/uploads/pd...fs-c249.pdf​
                                  • javieromex
                                    • Apr 2016
                                    • 83
                                    • México
                                    #137
                                    Can you Help Identify this?
                                    Its on LA-L243P Mobo.
                                    • kasfamily
                                      • Aug 2014
                                      • 774
                                      • Russia
                                      #138
                                      Maybe
                                      • javieromex
                                        • Apr 2016
                                        • 83
                                        • México
                                        #139
                                        Originally posted by kasfamily
                                        Maybe
                                        Thanks for you help. 🤝
                                        • javieromex
                                          • Apr 2016
                                          • 83
                                          • México
                                          #140
                                          Richtek G2=
                                          RT3652EBGQW
                                          Can someone confirm this? I think it might be wrong.
