laptop screen pull glue strips
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    can someone tell me where to buy replacement laptop screen pull to remove glue strips or even the official name? I cant find them anywhere, I have used double sided tape but thats a pain to remove sometimes if the screen goes faulty and needs to be RMAd
  • mon2
    • 14216
    Re: laptop screen pull glue strips
    Hi. Try "LCD tape". It is common for mobile screen repair. You can buy complete tape kits for macbook, ipad and imac markets on AliExpress.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Hi the official name is bond and attach from tesa.
      https://www.tesa.com/en/industry/tes...nd-detach.html
      https://www.mobilesentrix.com/tesa-6...25m-white-tape
      • reformatt
        • Feb 2020
        • 1412
        I managed to get some Tesa bond and detach (product number was 70465) from adhesives.com.au about 18 months ago. They custom cut a few rolls to the widths I wanted (6mm and 10mm). Cost me about $50 a roll if I recall. But considering Lenovo charge $50 for one pair of replacement adhesive strips for their flex series I thought it was worth it. It's slightly thicker than I'd like but works fine for all the screens I've done. It's particularly strong.
        Unfortunately, they didn't restock it when they ran out. But I'm sure you could find other adhesive places that would stock it and do some custom widths.
        If you are going to do this professionally, spend the money on the right tapes, as you might need to replace a hinge later on down the track on the same assembly. With some displays now going over $300 you'll live to regret it if you bodge it. Had one guy use VHB tape from Bunnings on one Flex 5 I worked on. I ended up rejecting the job after I spent nearly an hour trying to get the screen out and the lid screen retaining clips had also been broken off by the previous repairer.
        • DiamondTech61
          • Aug 2021
          • 61
          • united kingdom
          ok, thank you all for your feedback!
          • ACS-Repair
            • Feb 2021
            • 204
            I've used the "Command" picture hanging strips on a Dell laptop. They are short but I used one at the top and one at the bottom on each side. This will allow that screen to be removed in the future if necessary.
            • dspok
              • Jan 2014
              • 553
              • Nepal
              I use thin double sided tape left/right top and bottom corners instead of applying on whole strips.
              • VcemPzd
                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                by VcemPzd
                Hello everyone !
                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                04-28-2025, 10:14 AM
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
              • Admin
                Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
                by Admin
                Some sticky topics have been moved to this thread:
                - finding a compatible laptop screen with LED-backlight.
                Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
                MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
                Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
                12-27-2023, 03:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • almarhum
                To fix laptop screen vertical line by working on its EDP cable
                by almarhum
                Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                05-07-2024, 02:12 PM
