dell E6410 no power
  • bembeno
    • Feb 2016
    • 313
    • egypt
    dell E6410 no power
    dell e6410 la-5471p no power i measured the ic max17020e the vin is 19 v put no 5 v or 3.3 v should i replace it ?
  • mon2
    • Dec 2019
    • 14672
    Re: dell E6410 no power
    Which voltage rails on PU19 are missing ?
    There are the 2 x LDO low current rails supplied by this Maxim device.
    There are 2 x high current switching rails supplied by the same device.
    What is the voltage on pin # 4 (ONLDO) of this regulator ?
    Also, measure the voltages on the following pins of PU19:
    pin # 5 (RTC) - should be 3v3
    pin # 7 (LDO) - should be 5v0
    pin # 14 (EN_3V_5V) - signal enables / disables the switching regulator (5v)
    pin # 27 (EN_3V_5V) - signal enables / disables the switching regulator (3v3)
    • bembeno
      • Feb 2016
      • 313
      • egypt
      all the above is 0 volt
      just pin 6 =19 v
      • mon2
        • Dec 2019
        • 14672
        So the ENABLE pins for the LDO and switching legs of this Maxim regulator are OFF = 0v. This will then result in each of the 4 power rails to be DISABLED.
        The ENABLE pins are driven by the EC controller @ U36.
        Confirm the RTC_CELL battery voltage on this logic board.
        • bembeno
          • Feb 2016
          • 313
          • egypt
          i replaced the rtc battarey and now pin 5 = 2.6 volt
          the same rtc battery volt but there is no ldo or en volts
          • mon2
            • Dec 2019
            • 14672
            Confirm that VBAT is present to power U36 (RTC_CELL_VBAT).
            • Bonzas
              • 472
              • Indonesia
              Do you have AC_OK signal from charger ic ?
              • bembeno
                • Feb 2016
                • 313
                • egypt
                (RTC_CELL_VBAT) pin 64 = 0 v
                • bembeno
                  • Feb 2016
                  • 313
                  • egypt
                  if there is a boardview i want to find r544
                  • mon2
                    • Dec 2019
                    • 14672
                    Attached. It is from a paid sub that is locked.
                    • Bonzas
                      • 472
                      • Indonesia
                      https://www.badcaps.net/forum/showthread.php?p=868883
                      Download from post #17 if you don't have allegro viewer brd file from piernov
                      • bembeno
                        • Feb 2016
                        • 313
                        • egypt
                        Done thank u bro
                        • mon2
                          • Dec 2019
                          • 14672
                          Excellent. What was the fix ?
                          • PantherDave
                            by PantherDave
                            Hi all!
                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                            05-29-2024, 02:01 PM
                          • Mark01
                            Dell Optiplex 7490 AIO - red power led after flash
                            by Mark01
                            Hi guys,
                            This is my first post! ๐Ÿš€
                            I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                            Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                            07-04-2025, 12:54 PM
                          • zlr8r
                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                            by zlr8r
                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                            Ill try and give as much info as I can.
                            Dell Inspiron 17 (7786) Laptop
                            Service Tag: 5J0NHT2
                            Bios: 1.9.0
                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                            Then it started getting weirder!
                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                            12-12-2023, 09:31 PM
                          • LimesKey
                            Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                            by LimesKey
                            Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                            10-17-2025, 05:33 PM
